Alloy/steel wheel bolt differences? (4 Viewers)
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
My 2015 Ducato has alloy wheels and I have a steel wheel spare. Does anyone know if the fixing bolts are the same? I contacted Fiat and they could only give me the number for the steel wheel bolt (which has a length of 62mm and thread length of 22mm according to t'internet). When it stops raining I'll take one of my bolts out.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
I just spoke to a guy at Tyremen (who I got my spare steel wheel from) and he says bolts are the same. I will check shoulder angles on both wheels if I can.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I bought some steel wheels from a new Hymer. He'd had them changed to alloy by the dealer and they used the same bolts. He too was concerned but they assured him it was correct so he asked them to put it in writing.
@Brian and Jo will know :p or at least better placed to find out.
Personally I don't think tapers have to be the same angle so long as the bolt is long enough and the tapers meet. If they were exactly the same angle the contact area would be so wide they'd most likely seize
2657
I would be very careful in assuming that the bolts are the same, not all ally wheels are the same.The thickness of the aluminium and type of taper are very important.
Are the ally wheels a Fiat supplied part or aftermarket fitted by the dealer.
I had a Hymer caravan with ally wheels and a steel spare the bolts were different, even a different spanner size.
stevec
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
Alloys were factory fit by Burstner so no idea if supplied by Fiat on the base chassis.
Badknee
7,408
412,853
notloB
Vantage Neo
Living the dream.
If they are going onto studs then it may be ok but I would think bolts would need to be different lengths.
makems
3,440
27,702
Ingleby Barwick,,Teesside
Sadly had to give up
I am in same situation. Alloy wheels, steel spare.
I have asked every time the van has been to the dealer for warranty work and been assured every time that the bolts are the same.
I have always asked a different mechanic to see if I get a different answer :)
Techno
Jul 28, 2010
15,475
20,756
May 2010
The standard bolts are miles longer than needed for the steel wheels hence why they all say they are OK for the alloys
Aug 21, 2015
91
44
Southampton
A/T Impala 615
I'm a slightly less experienced newbie and still learning
Just traded caravan in, it had alloy wheels and steel spare supplied from new with different bolts for the spare. By eye the difference was length. Imagine the same would be true with MoHo.
"Nine tenths of wisdom is being wise in time" T Rossevelt
Techno
Jul 28, 2010
15,475
20,756
May 2010
All the X250 bolts are long
http://www.motorhomefun.co.uk/forum/threads/spare-wheel.127188/page-3#post-1798826
image-jpeg.97629
12,266
45,055
Nearly Tugging
I have alloys and a steel spare. I checked with main Fiat agent in Norwich who confirmed no different stud required.
makems
3,440
27,702
Thats comforting, but I wold still like it if someone had actually managed to put a steel wheel on with the supplied alloy bolts.
id try it myself except we are touring Morocco at the moment and the garage is rammed full of stuff and I don't want to spend a day unloading it to get the spare out and then reload it all again.
and anyway I'm not sure since my op whether I would be capable of handling the weight of the wheels.
Feb 22, 2008
12,266
45,055
Nearly Tugging
Yes the hardest bit is lifting and locating wheel on hub while trying to line up studs with holes.
I would use my roadside assistance where possible.
737
3,578
newark
Swift escape 624
I use a steel spare, but kept all the old bolts and guide studs when i fitted alloys, i have spares if required by anyone
Aug 21, 2015
91
44
Southampton
A/T Impala 615
A further comment to all the good advice given is that the recommended torque settings are higher for a steel wheel. (At least that was the case with caravans where my experience lies).
Recent convert to MoHo still awaiting delivery!
