All my solar kit has arrived!
Discussion in 'Solar Power' started by Trikeman, Jan 17, 2014.
  1. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    After much toing and froing, panicking and fretting and absolutely superb advice and guidance from our Techno100 (many thanks Andy) and Vlad the great impaler, all my solar kit has now landed.
    2x100w panels, 20a MPPT controller with remote screen/control, end spoiler mounting brackets, fuse boxes, 6mm cable, ends, screws, Sikaflex, activator, etc etc. I even ended up with a mini 12v solar (briefcase) charger toboot.
    :thumb:
    Oh' I can feel myself getting all 'environmental' and 'dreadlocked' here, where's the trees to start hugging, chanting and my patchouli oil......
    :Laughing:
    Now waiting patiently (read finger tapping) for a bit of fine (but not too cold) weather. Fitting the controller and cabling tomorrow. The 2x100w panels are going to be cabled up in series to give 24v and the MPPT will bring this to 12v to charge my 2 x 110ah batteries in parallel.
    I have removed a great roof rack to fit the system - will be up for sale if anyone is after a cracking roof rack,,,, not a cheapy either.:BigGrin:
    I am REALLY, REALLY looking forward to this project. Harri Kryshna!
    Trikeman. :Wink:
    • Like Like x 3
  2. simbadog
    simbadog Funster
    Sep 12, 2012
    1,293
    2,184
    Wengen
    I'm thinking of getting rid of my solar & replacing it with a water wheel :RollEyes:
    • Like Like x 5
  3. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    I am now expecting an eclipse that will last for weeks:Rofl1:
    • Like Like x 4
  4. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,615
    2,189
    Rutland
    Hope it all goes well Kev, :thumb:
    As for advice and guidance that's what this forum is all about.After all I picked up all mine from a local Andyman !:Smile:
    Vlad
    • Like Like x 1
  5. UK Pete
    UK Pete Read Only Funster
    Jan 16, 2014
    285
    334
    kent
    Hi what kit did you go for and how much was it if you dont mind me asking
    pete
  6. Addie
    Addie Trader - Motorhome Wifi
    Oct 15, 2011
    400
    406
    York
    Which MPPT controller did you go for?
  7. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,048
    3,450
    walthamstow east london
    are you sure about conecting in series as panels give out 18volts i htought they were normal wired in paralel therefore producing 18v s at higher ampage than a single panel and the controlller drops this to the required voltage for the battery
  8. Steve
    Steve Funster Life Member
    May 8, 2013
    1,563
    1,837
    Compton Berkshire
    Sounds like a great kit, very similar to mine. But why series?
    Did the kit by any chance contain a box of sun?
  9. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    The point about MPPT controllers is that the input voltage can be much higher, some up to 150Volts.
    The popular Victron BlueSolar Charge controller MPPT 75/15 installation manual is here http://www.victronenergy.com/upload...controller MPPT 70-15 - EN_NL_FR_DE_ES_SE.pdf
    The manual states:
    12V battery and mono- or polycristalline panels
    ● Minimum number of cells in series: 36 (12V panel).
    ● Recommended number of cells for highest controller efficiency: 72
    (2x 12V panel in series or 1x 24V panel).
    ● Maximum: 108 cells (3x 12V panel in series).
    Increasing the voltage instead of the current minimises the cable loss.
    Gordon
    • Like Like x 1
  10. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Uummmmm! What Gordon said :Laughing:
    I have been recommended to fit them in series by the suppliers, you could reduce the size of the cable cross section with the 'in series' set-up. However, all guns blazing, I'm going for the 6mm cable AND the in series set-up. As stated above, the MPPT controller will take what the panels can throw at it and give the best output to the leisure batteries.
    Regards,
    Trikeman. :Wink:
  11. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Hi Addie,
    I went for the 20amp Tracer MPPT controller - if you have a look at the 'Trikeman's solar diary' thread I have put a photo of it there, complete with it's remote control screen.
    Hope it helps.
    Regards,
    Trikeman. :Wink:
