Additional Leisure Battery. (2 Viewers)
mark e
242
Rhondda Valleys, S Wales
Year 3 of ownership !
As you are aware i have one 85ah battery situated under the passanger seat, and wanted to go down the generator root way of things, but with the price of petrol at the moment, was wondering how economical it would really be.
I have a Fiat ducato cab, with a battery under the passenger seat and wanted to buy another one. There is a photo of a ford transit with 2x 85ah batterys fitted under the seat.
Would 2 fit under mine ?
American Dream
156
Lincoln
Hi Mark.
Your link isn't working.
Is the space left under the seat equal to,or more than, the size of the existing battery?
If there is room for another then I'd personally fit one.:thumb:
Sorry can't be any more specific without pics.
3,995
6,255
Rochester
Auto-Trail Mohawk
16 fun filled years
Mark, get the dimensions of the battery you are considering buying then mock one up out of cardboard so you can try it in different positions before you buy.
mark e
mark e
242
i've borrowed this picture from another member, (sorry) but this is a ford transit seat.
As you can see, it fits, and assuming that the seats in my fiat ducato are of a simular size. HOPEFULLY.
This is my intention, but i dont know how to tie the 2 batterys together and make sure they both charge of the engine altenator. Can somone explain this, in english please :ROFLMAO:
And i've also bought a 600 watt inverter, which i want to do as in the picture.
As usual, thanks in advance !
P.s my charging unit is not under my seat, there is only one 85 ah battery there at the moment.
BJ
62
Its a bit pointless having the dimensions of a Tranny seat base, when you have a Ducato.
I have a 06 Ducato, and the seat base will NOT take any battery bigger than a single 85ah battery, as you have the previous model Ducato there may be more room.
Voyager
10
Sheffield
March 2007
Hi Mark I have a Ducato 07 and wanted extra leisure battery power, there was one battery under the seat behind passengers seat which was 110 and was advised to keep to 110. Unfortunately couldn't get another along side so decided to put one under the other seat, could only get one there because of water pump and frame of chassis. But managed two under the rear bed.
:thumb:
Geoff
mark e
mark e
242
Behind my passanger seat i have seating with the table, but i have the water tank there, and it fills the space.
Been out to the motorhome, have thought of another idea.
Nothing under drivers seat, so could put another battery there :thumb:
Would it be okay to put the battery under there ?
What about the cable that joins the 2 batterys together ? it would be passing the space between the 2 front seats ( the walk through ).
What about charging the 2 batterys, on the go ? will my engine alternator cope ?
What about EHU ? will my charging unit cope okay with charging the 2, 85ah batterys ?
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
I prevously had a Bessecar & fitted another 110 under the drivers seat, it just went in, but measure it carefully. :Eeek: There may not be room if the seat is a swivel type.
I ran the wires under the carpet between the seats, there was a lip in the floor so I ran them taped close to that.
As far as I could tell the engine coped well with charging the extra battery & my solar panel worked with the set up.
My present motor home has 2 110's and the built in charger copes with charging them.
No doubt someone will shortly mention that two batteries should be the same age and size to be effective as well as having leads the same length. If you are not sure about connections please ask someone before you try it :thumb:
Gonewiththewind
846
36
Lancashire
July 2007
mine is a Boxer base and had an 85 APH, I removed this and extended the cables through to the side bench fited retaining straps and 2 x 110 APH Batteries, all seems to work fine. was a bit concerned as the charge unit is only a 10 amp . fingers are crossed.
G
GeorgeTelford
Yes it will cope, all that happens is that it takes longer
There is often a small "channel" between seats, molded floor gutter under carpet, that you could run the cable through, I have Duct taped wires there in the past (do not forget to add a fuse to this link)
2,337
10,145
Good link George ..
I'm going to renew the battery cables and clamps when I get new batteries, can anyone suggest a good supplier .. ?
