AC Unit wanted (1 Viewer)
ObiVanKenobi
42
St Andrews
Panel Van Conversion
New to the forum so im not even sure if this is in the correct area but here go's....
Looking for a roof mounted AC unit to fit to my Citroen Relay Panel Van (being converted as we speak). Preferably second hand as new ones are just too expensive at the minute. Looking to purchase asap.
P.S please forgive the username, so many are taken it had to be quick thinking of for this one!
Steve
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Dont forget all modern roof mounted aircons are mains only. If you can find one like I have which is an old Trav-l-cool they are 12 volt. Unfortunately they stopped making them some years ago. The benefit of this model is that it can be used whilst on the move.
O
ObiVanKenobi
42
St Andrews
I have recently been looking into the possibility of using an inverter, large alternator, B2B, large batteries and solar set up to power the AC unit independent of hooking up to a 230 power supply. Seems like it may be more hassle and money than it is worth.
Only reason for us wanting to set up like that is because we dont use campsites much however, the money for the setup may be better used to pay for hook ups instead of unproven AC/Inverter setup.......
Anyway, for now I am just looking for a unit. Any will be considered.....
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
You'd need a field of solar panels to power an air con (I'd think at least 2000W worth even for a small unit). However, at least when it is hottest, you'll get the most ampage from the panels. You won't last 5 minutes on battery, though, unless you basically turn your vehicle into a milk float.
I wonder if anyone makes gas powered units?
O
ObiVanKenobi
42
St Andrews
The AC would be powered by the inverter the solar would be there to top up the field of batteries so the AC wouldnt run directly off the solar. Your right though the smallest AC unit I found would need 2700w of 'inversion' however lots of other things actually make the set up unrealistic.
A gas powered unit would be handy though!
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
hi if your looking for a 12v ac Travel-L-Cool theres one on Ebay
Link Removed
I was going to ask if there was such thing as a motorhome evaporative cooler. Seems like there is. Evaporative cooling would be much more sensible on battery than a closed loop compression system. Not as effective, and uses a lot of water, but only needs a fan to be run.
Also, not so good in high humidity.
O
ObiVanKenobi
42
St Andrews
Thanks for all the help, I will research the Trav-L-Cool a little more tonight. Looks like a good bit of kit for the price....
Bailey58
8,817
29,589
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
I have a roof mounted aircon unit by Dometic/Waeco powered by mains when on EHU of course but also wired through a 1600/1800W inverter, can't remember, for use whilst the van is in motion. The van spent some time in the sun at one time so with no cab aircon this must have been installed, at great expense, to do the two jobs.
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Evaporative coolers can be prone to harbouring Legionella bacteria.
Spacerunner
607
197
Hampshire
Do you really need habitation air conditioning.
You are going to travel to southern Europe for warm weather then spend good money trying to negate it.
If hot weather bothers you that much then keep to more northerly latitudes and spend your money on something really important.
i qualify this by only being converted to cab A/C five years ago and truly appreciate it for a more comfortable driving experience.
Habitation cooling? A good fan should suffice and loads cheaper and versatile too.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
There is a 25 litre water container under the wardrobe on mine, but I have never felt the need to put water in it. It still blows cold without water. I always thought the water was just for dry climates.
