Absolute Satellite Beginner (2 Viewers)
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
I am almost embarassed to post this, but...
My old Hymer has two satellite dishes, but no TV or anything.
I have absolutely no idea how satellite TV works, would I be able to use either of these dishes? Why might it have two? what equipment would I need to get to receive Freesat - all on 12v at the mo, but am considering fitting an inverter, I know a little about those (c:
O
Old Soldier
Hi Baccus.
I assume your dishes are portable or is one mounted on the roof? Do you not have a receiver of any sort?.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
stick with 12v for the receiver or just go with an avtex TV which runs on 12v and includes both terrestrial and sat decoders. Are the sat dishes manual or automatic, wind up or dome. I suspect one of each or no point of having two. a photo or two would help.
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Hi Old Soldier, the dishes are both roof mounted. All I have done with them for three years is collect moss...
There are handles inside the van for elevating and rotating them, but no, I have no equipment- my limit in this field is putting up a TV aerial on the house and connecting it to a freeview box...
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Hi Wildman
Dishes are both manual winders, I will get a couple of pics in the morning.
So I could just connect an "avtex" TV and plug the satellite into the back? As long as the satellite was aligned it would work like "normal" TV?
O
Old Soldier
Sounds like Wildman might have the answer.
lorger
9,663
90,508
Dumfries
Knaus Sun 650MEG
Just a thought could one be for satellite internet, seen a van at Chester meet with two dishes and one was for Internet.
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
It's a 1991 van... It may have had satellite internet added of course. I will get some more useful details in the a.m
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I'm just wondering if they are actually both sat dishes.. to the uninitiated some campervan / caravan ariels look like sat dishes..
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Hi Wildman
yes just make sure the model you get is DRS the "S" being satellite. just plug in align dish and away you go and uses under 2 amps so battery will last longer.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Before you spend any money, check that the dishes are for digital satellite reception. If they are old ones, they may have come from the analogue satellite era and no longer work. A picture will help identify this and you could do worse than make a call to Roadpro (or similar supplier) if you need technical advice.
RoadPro | Practical Products on the Move
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Hi All, thanks for the advice thus far!
I have clambered up the back and taken a couple of photos, no idea whether they will help to identify. This is the main dish
this is the controller underneath
And this is the other dish; I am beginning to wonder whether this is just some kind of TV aerial...
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
Top is a Maxview crank up Satellite dish, and the lower one is a TV aerial. (y)
As long as the dish feed cable and the LNB ( device on the end of the dish arm) are OK you should be able to set it up for a Satellite receiver or a TV with a built in receiver.
Nov 14, 2009
425
252
normandy
c class
16 years
first ones a maxview wind up dish for satelite tv and if pointed at astra 2 with an appropriate receiver will give you tv, the second is a tv/radio antenna for terrestrial services and will give you digital tv if you have a receiver for that.
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
woo-hoo - many thanks!!
I shall buy a TV and give it a go.
I quite like being away from the TV when I am with GF Bacchus, but will be heading off for a week or two solo and it would be a nice to have (c:
Hammie
467
278
Neismann & Bischoff Arto
newbie/2015
I haven't got mine going yet either, are you the man who I met at Baker Tyres?
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Hi Hammie, sorry, not I. Never heard of Baker Tyres...
As an addendum to my post, I have also found this:-
Which I guess I just connect to the satellite output and wiggle the dish aorund until the green light comes on? No power supply, but presumably gets enough gain from the satellite cable.
And this:-
Which looks like some kind of signal booster.
An enterprising previous owner has put a dual switch system with a "main" switch inside the hanging locker and a microswitch on the overhead locker door, so with the main switch on, this box is activated when the locker door is opened.
Now, must get myself a telly... (I am not going to ask which one on here, that seems to be as divisive as "anchor" threads on a sailing forum I go on :whistle: )
Hammie
467
278
newbie/2015
Baker tyres Thorpe lea road. Met a man from Warwick Avenue (truly) same campervan
Hammie
467
278
newbie/2015
Have got maxview satelite as well thinking about maxview satellite Finder but it is £30 instead of £13? Other option is £9 on Amazon for another brand not sure which way to jump
Hammie
467
278
newbie/2015
I love previous owners output, solar panel, awning, Safari room, satellite dish, love my new second home. Too much red nite nite
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Oh that Baker Tyres...
Amazing. A few hundred metres from my house, but no, not me!
Hammie
467
278
newbie/2015
Good for tyres and they were inflating mine and the other mans before a trip. Where do you go to inflate yours?
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
"Where do you go to inflate yours?" - weirdly, in three years of ownership, I have never had to!!
Mar 23, 2015
93
122
North Nottinghamshire
Autosleeper Kemerton
Since 1989
I have a maxview satellite finder and it is the only way I can ever find the things, love it! Wait until it screams its head off, annoys everyone on site and you will be sure of a picture. Tried loads of others cheaper to no avail.
Good luck, took me weeks to see a pic!! but thats me!!
Hammie
467
278
newbie/2015
Ha ha thanks. Me too. Will order it now. Mary
Hammie
467
278
newbie/2015
Won't you damage your tyres? We just give them a £5 tip before a trip at least that's what the man with the same Motorhome as you told me he did. I am worried that the tyres might crack if they get low? Expensive tyres. They said it can't be done in a garage as the compressors are too small.
Bacchus
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Never tried it, mine run at around 70psi, I would imagine that most garage compressors will run to that but you're right, it would be a good idea to be sure.
Mine haven't lost any pressure, so haven't pumped them up
Hammie
467
278
newbie/2015
Amazing lucky you!
