A gas thread - No, not that type!!! (1 Viewer)
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Am looking at buying a van with a gaslow 2 bottle system fitted. External fill point, all good.
However, what I can't get my head around is this - if you were static on a winter site for longer than the on board gas lasts, other than moving the van and driving to a garage, how can you get gas?
I don't want to entertain any Micky mouse filling of a gaslow bottle or anything dodgy, the questions is -
Can you connect a locally sourced 'normal' gas bottle of the country you are in to the system? In other words, the ' normal' way, is there a hose that you can simply fit an appropriate regulator on and use say a Repsol bottle simply connected to the van, as if the gaslow system wasn't there???
Tia!!!
May 31, 2015
11,726
44,676
Ducato PVC
Getting Better
Yes Dave have a look at the gaslow site you can get a hose that plugs into the fill point where you can connect a local bottle...
I'll try and find a link for you....
BreweryDave
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Sadly not, only an external fill point for the gaslow. Can you connect a bottle to that???
Edit - answered above thannk you sas!
Dec 10, 2013
3,424
12,305
South Staffs
Pilote P740GJ
I believe you can get a fitting that will let you use a stand alone bottle.
Edit Sas r us beat me to it.
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
I see lots of Brit and other non-Spanish motorhomes here in Spain and Portugal with an extra "T" and valve fitted into their gas cupboard gaspipe line. From that T and isolation valve they run a flexi hose, terminating with a bottle-top connection/regulator which is standard for all Spanish and Portuguese gas bottles. Thus a locally sourced Spanish bottle can sit just outside of gas cupboard and be what they use whilst down here.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
If you have a BBQ point fitted you can fit a standard gas bottle to it (via its own regulator)
But.. what if there is no external gas point?..
I was shown a spare tail setup to the plumbing in the locker to allow for a "standard" bottle to be fitted if required... (kept in another locker) can't remember how it was configured. It was a couple who full time up in Scotland often... Met them at Cleethorpes last year wilding. They where called John & J?.. and have "JJ" on the bonnet of their Moho.
Funsters?..
Edit... slow tinternet today... seems sorted above :)
32,689
66,703
On the above link it says:
The Gaslow Reserve Cylinder Connection Hose enables the connection of a reserve cylinder to the Gaslow filler point.
Perfect if you are on site and don't want to move your caravan to find a filling station.
The hose screws into the internal thread on the Gaslow Fill Kit.
The other end of the hose connects directly to any 21.8LH cylinders or our range of Gaslow 21.8LH Adapters, so you can connect to all European cylinders.
The gas will be drawn from the reserve cylinder, through one of the refillable cylinders to the regulator.
Note that it will not transfer liquid gas into the refillable cylinder, so gas from this cylinder will only be used if the refillable is empty.
But ... if your other cylinder(s) is NOT empty it won't use the external gas supply so if you wanted to use it instead of your refillables it appears that it wouldn't work like that whilst there is still some gas in them ... although you could use it if you've run out totally.
This seems to be a drawback ... if you wanted to keep some gas in your refillables (eg for when you leave in case you don't find anywhere to fill up for a while) it would appear that you could not.
32,689
66,703
That brings up another question ... I was under the impression that if you have a bulkhead regulator fitted you shouldn't then use a regulator on a bottle too but instead a connector that is NOT a regulator ... on the Gaslow link it shows various non-regulator connectors for bottles.
32,689
66,703
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
How does it fit/where?
The pipes from the Alugas bottles go to a central switchover, just disconnect one of the bottles fit the spare pipe and connect to a free standing bottle. Turn the switchover to the side you fitted the spare pipe too and that's it job done, takes 2 minutes.
32,689
66,703
That's the way I'd prefer to do it too so looks like Alugas have thought it through a bit more than Gaslow!(y)
53,617
150,689
If you are static for longer than 22kg of gas will last you in southern Spain you are not doing you van any favors. Need to take the van for a good run and get the engine and gearbox fully up to temperature at least every 3 weeks so why not ccombine it with filling up with gas.
Scattycat
920
1,262
Mayenne, France
Rapido
We over come the problem by just having one gaslow tank and one refillable one so that when the gaslow is emptied we switch to the refillable until we can get to a gpl pump
Forestboy
5,023
8,338
Forest of Dean
We've only had to use it when skiing and staying for a couple of weeks.
You are right though and when skiing we start the engine everyday and run for 15 minutes.
32,689
66,703
Why?????
Fletton
1,531
2,501
Lincolnshire, UK
@Minxy Girl A way forward...
I have 2 * 11kg bottles... and NO auto switchover... when 1 bottle is empty... use external... saving the other 11kg for when moving off site. Sorted :)
32,689
66,703
Not sure that would work ... its the inlet to the bottles that can't be isolated, not the outlet so whilst you can stop gas being drawn from one of your refillable bottles by closing the outlet I'm not sure you'd be able to stop the external gas supply going into it ... however as it would be 'gas' rather than liquid the gas might fill the 'off' bottle then go through the 'open' bottle ... never tried it but in theory it might work ... what do you think????
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
We have been using the Gaslow Reserve Cylinder Connection Hose for the past four years without any problems.
It has worked really well for us during our winter trips to Spain.
Brisey.
Fletton
1,531
2,501
Lincolnshire, UK
@Minxy Girl I think its no different than just having a single empty bottle... as the second is effectively isolated...
tonka
10,841
21,557
Cannock, Staffs
A class Burstner 800
Since 2000
Jumbo adaptor, simple..
If you have a Butane hose, unscrew the UK clip on adaptor.
Screw on a Jumbo adaptor ( it's not a regulator). and the job is done.. This then uses the bulkhead regulator and everything is as it should be :)
Oct 29, 2008
5,078
5,990
West Yorkshire
If you are connecting to a BBQ point you must use a regulator as you are already past the bulkhead regulator fitted to the van. Its the recommended way to connect a gas bottle to a van with a fully fitted gas tank (i.e. an underslung tank)
This is the way my system has been designed and fitted by Autogas2000
32,689
66,703
So, just to recap:
If you have a BBQ point you should use an external bottle with a regulator on the bottle and connect the pipe to the BBQ point, therefore a low pressure hose can be used.
If you do NOT have a BBQ point and instead are going to connect the external bottle direct to the pipework (before the bulkhead regulator), or via your cylinders using the Gaslow filler, you should NOT use a regulator on the bottle, but must use a high pressure hose.
Fletton
1,531
2,501
Lincolnshire, UK
So, just to recap:
That's how I understand it... :)
