a class windscreen keeps steaming up (1 Viewer)
clive jones
essex
a class
since 2005
hi i own a eura mobile motorhome .it is a large screen as it is a a class. i have to have the aircon on to clear it as the blower is not strong enough to clear it.its a real pain driving in the cold with aircon on wearing coats. i changed the thermostat. any ideas ?
jonandshell
5,476
8,299
Not got one!
Will the aircon not work whilst you have the heater turned to hot air?
Every vehicle with aircon I have ever driven does and clears the windscreen easily whilst you keep warm.
32,667
66,625
Welcome to the fun house Clive!
It might be an idea to try to reduce the amount of condensation that builds up first and then use the air-con to get rid of what's left. Is there any particular situation when it is worse? For example do you have external screens for it, do you ensure that you let moisture/steam out when cooking etc?
43,332
49,525
This appears to be a problem while driving....;)
Feb 24, 2013
13,088
101,491
Bolsover, Derbyshire
Hymer S800
not long enough
I regularly get similar, but as Jon says use your air con with heat, we do virtually all the time, it might take 1mpg, but we only get 20mpg anyway
I did have a car with a heater fault once though that occasionally seemed to pump steam at my windscreen, I was quoted so much to fix that I traded it in sharpish, hopefully yours just needs some heater control adjustment (y)
Welcome in by the way :)
Jan 22, 2013
1,254
60,457
London SE
A class Adria vision I707
since 1971
You should use your air con all year round to keep the seals supple and lubricate the compressor, using it with hot air isn't a problem that how it's meant to work,
The other big problem I see most days are people leaveing the heater on recirculated air in the beleaf that it warms up quicker,
It may do initially but the moisture content goes up creating fogged up screens,
2,344
10,183
Likewise.. (y)
to de-mist you need DRY warm air..
to get that you need to use the air con (to knock out the moisture ) + heat from the heater
C
clive jones
essex
a class
since 2005
thanks for getting back. when driving i carnt have heater on screen especially when its cold outside . before i start a journey i use a karcher hand window cleaner to suck all the condersation from the inside of the screen. i have to drive with the aircon on. things are starting to drop of me its that cold. i dont have a external cover as i have a electric front screen. the main problem is not enough blow to the screen.
Oct 2, 2012
149
169
Shoreham by sea
c class
I'm a newbie
On your heater if you have a knob you can set to air circulating or fresh air coming in put it to air coming in it works in my vans hope this helps .
Gary.
Feb 24, 2013
13,088
101,491
Hymer S800
not long enough
A bit more confusion here I think, the external cover has a different function to the electric front screen nothing stopping you having both
That said I have not seen an electric front screen on an A class or any other MH for that matter
But if the screen is heated the misting up is even more confusing
and I really do not understand why you say you cant have heat on the screen when driving
Dec 13, 2013
58
41
peterborough
a class
just started
I had a Saab 9000 where water could get into the aircon system after the dryer and fog the inside of the screen. I think a drain had become blocked, a mechanic that knew the system fixed very quickly and the problem never returned.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Gary.
I'm with Garry on this one.
It always happens to us as I switch the control to re-circulating when stopped for any length of time as there can be quite a draught coming the heating system when windy. Then, very often forget to switch it back, and it always causes the windows to mist up.
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Can I throw in a Thanks?
I've got this same problem with my car--has been driving me potty. Now realise it's the recycled air!
Thank you, all.
Nov 30, 2009
6,548
149,012
Pickering
PVC the PUG
My old car used to do this. But only if someone or something was wet inside. Be it a dog or jacket etc. Or if I had jet washed it.
19,369
30,347
I guess he means the screen/blind inside the windscreen which can be electric if you are posh, no substitute for good silverscreen outside though.
19,369
30,347
Hi Clive
Being an A class the dashboard will be modified and the screen vents will not be the original van ones, on ours there is a big plenum underneath the dashboard cover which sits onto the original van screen vents and then takes this air to the new position at the screen base, is it possible that the piping or whatever system Euro mobil use has come undone and the air is just getting lost under the dashboard rather than blowing onto the screen.
denisejoe
5,622
12,054
Warden isle of sheppy
I also have a Euromobil A-Class and you have to use the extra front heater to demist the front windscreen the one on the passenger side of the dash it runs on gas . The normal engine heater does not blow onto the screen the vents at the front are adjustable. You don't have to have the heater on but just use the fan.
Joe
