This appears to be a problem while driving....Welcome to the fun house Clive!
It might be an idea to try to reduce the amount of condensation that builds up first and then use the air-con to get rid of what's left. Is there any particular situation when it is worse? For example do you have external screens for it, do you ensure that you let moisture/steam out when cooking etc?
Every vehicle with aircon I have ever driven does and clears the windscreen easily whilst you keep warm.
i dont have a external cover as i have a electric front screen.
On your heater if you have a knob you can set to air circulating or fresh air coming in put it to air coming in it works in my vans hope this helps .
Gary.
A bit more confusion here I think, the external cover has a different function to the electric front screen nothing stopping you having both
That said I have not seen an electric front screen on an A class or any other MH for that matter
But if the screen is heated the misting up is even more confusing
and I really do not understand why you say you cant have heat on the screen when driving
