8mm pipe bending (1 Viewer)
MattR
4,105
38,897
Beds
Panel van
Years
I'm installing an auto changeover valve and regulator and need to replace a rubber hose with 8mm copper pipe. I have a 10mm pipe bender that does a pretty good job of creating the 90 degree bends but the pipe is crushed more than I would like (although, no where near flat). Does a reduced bore make much difference with gas or am I better off using elbow joints or bending the pipe with salt or sand inside?
D
Deleted member 29692
Yes, it weakens the pipe on the bend. You need to get an Broken Link Removed or spring.
Where in Beds are you? I've got a 8mm pipe bender you can borrow if you want?
MattR
MattR
4,105
38,897
Beds
Panel van
Years
Thanks. We're in Bedford. Do 8mm benders have formers? I've heard that many do not and I wondered what effect that had on the final profile.
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
B & Q have 8mm external springs in plumbing section
D
Mine does I think. The profile is fine. I'll dig it out of the garage later and double check.
MattR
MattR
4,105
38,897
Beds
Panel van
Years
I haven't had much luck with springs - do the external ones just reduce the are in which the bend takes place?
Nov 4, 2011
5,941
38,967
Uk
When I put my bbq point in, I made a former with washers.
Get washers with outside diameter of required bend and stack to thinkness of pipe and then put a larger washer each side and bolt together. Larger washers stop pipe spreading and flattening.
MattR
MattR
4,105
38,897
Beds
Panel van
Years
Sounds like a good idea. I'll have a play later and see if I can set something up like this.
May 7, 2013
845
1,353
RUK
No not really I've bent 8mm copper to less than 90 degrees with no real problems other than getting the pipe back out of the spring (Applied lubrication always helps!)
MattR
MattR
4,105
38,897
Beds
Panel van
Years
I have 90 degree compression and solder joints but I would prefer it if I can create a 90 degree bend effectively. I am fine with wet plumbing and have leak detector gas and a gas alarm plus a friendly heating engineer who can check for me once installed.
MattR
MattR
4,105
38,897
Beds
Panel van
Years
KY, washing up liquid or something more dedicated?
Dec 12, 2010
5,413
21,580
Cumbria
since 2011
The secret to using bending springs, internal or external type is to bend slightly further than you need, then straighten it back to the required angle, this helps stop the spring jamming against the pipe when you come to remove it (y)
Aug 18, 2014
23,786
133,730
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
By keeping tight against the side you can bend around a small paint tin without losing shape. Failing that if you have insulation to go over pipe fit it first then bend & it will do so without crushing.
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
The Rothenberger (sp?) benders are worth buying for doing a nice bend, the cheapo copies not so good.
I use springs a fair bit, used to do air brake conversion on trucks and that was on steel pipe.
Peter
