230v Socket Tester At Aldi. (6 Viewers)
O
Old Soldier
On a recent Motorhome guided tour I was surprised how many people did not have one of these, nor a conversion cable or device and were unaware that some sites had faulty wiring with reversed polarity. Out of the ten or so sites that we stayed in, seven were faulty and all were 4star!!, indeed, some had a combination of good and bad, even on the same electrical supply point.
2,347
10,197
no surprise .. no earth being the most worrying..
but out of interest.. when you identified a faulty supply... what then.. ?
a) don't use
b) don't use and report
c) carry on regardless
d) try to rectify, (fix reverse polarity and install an earth spike )
e) go to another site
O
Old Soldier
a) don't use
I have a reversed polarity cable on board, some others were swapping live and neutral connections on their cable plugs. Some were not bothered..
There was an earth, just that the switched and fused side of live and neutral were reversed.
2,347
10,197
thanks.
no earth is rare.. but not unknown..
reverse polarity common but not an issue in a continental van ..
On reflection.. I think the safest way in Morocco is not to use EHU .. plenty of sun for solar power :)
O
Old Soldier
thanks.
True in most cases. I had an expensive CD player distroyed by reversed polarity a few years back. I had left it connected, switched off at the socket, when I left one site in France. Plugged into the new supply at the next site. Tried to use it awhile later and found it dead as a do do. On investigation someone showed me that we had reversed polarity, first I knew about it. Can't be sure of course but bought a tester and polarity change lead and used them ever since. Apart from fuses and trips not working I have also heard tell of some van battery chargers having problems so I don't take the chance any more...:smiley:
18,035
48,143
This may cause further confusion but it might be worth trying to explain what reverse polarity is, because it is nothing like the reverse polarity you wouldwould get if say you installed the batteries in a portable radio the wrong way round.
The voltage between the live and neutral wire is constantly changing between positive a negative. So one moment the live wire is positive, the next it is negative. If you measure the voltage between these wires with a suitable meter you will find it will be something between 220 and 240 volts, depending where you live.
Now do the same measuring the voltage between the live and earth and the neutral and earth and you should see something odd. Between live and earth you should get the same 220 to 240 volts but between neutral and earth you will get a very low figure between zero and a few tens of volts at most.
The explanation why this is so is the tricky bit but I'll try.
Ignore the lower diagram above and just look at the top one. The three wires connecting the tips of this star are the three electrical phases, normally called red, yellow and blue. The wire in the centre is the neutral, confusingly in a domestic house also coloured blue but that's just a coincidence as it isn't the same as the blue phase. Your domestic supply will be taken from one of these phases and the neutral, it will be reduced by a transformer from say 11,000 volts to 240 volts but the point is it is a feed between a live phase and the neutral. In any one area the three phases are shared out with some houses on the red live supply, others on the blue and the rest on yellow. This is called load balancing.
Some industrial sites receive a three phase supply so they can run things on 415 volts, which is the voltage between each of the three phases - the lower diagram shows this. These do not use a neutral at all but we can ignore this case in the context of EHUs.
At the local sub-station the neutral wire is physically buried in the ground, this is why the voltage you measure between live and neutral is very low, ideally zero but sometimes a little higher due to local variations of load between the three phases.
Now when your Aldi device tells you the supply is "reverse polarity" it doesn't mean positive or negative is reversed, it means what should be a neutral wire is a live one. The danger is if you only have single pole switches in your MH, which cut off the live feed, you could still get a shock from the device because the unswitched neutral wire is carrying the full 220 to 240 volts supply and this is what you will experience if you touch it.
So in summary, reverse polarity won't damage your TV or whatever, but it does have the potential to damage you if your MH doesn't use an electrical system which can cope with reversed polarity, which do exist.
A further risk of reversed polarity is how the protection device your MH works when live and neutral are reversed and the voltages and currents it is sensing are not where they should be, but I think that is enough for the moment!
In conclusion, use a reverse polarity tester if you are unsure what sort of electrics you have and use it in all cases if you want to check if there is a working earth - which is a very sensible thing to do. :)
O
Old Soldier
Don't know about the confusion.......fell asleep half way through it!!:snooze:
Only joking, good explanation. Simplified, test your supply each time you connect, at least you will know if your toaster is still live if you " accidently" scoop out the bread with your metal knife!!
:think::think::tmi::tmi:
Reactions: DBK
O
Old Soldier
Question for the elecxperts.....:think:
Firstly,
We all know that sockets may still be live even after they are switched off on reversed polarity hookups but does this also mean that fuses, that may be on the "live" side of an appliance plug for class 1 equipment will not blow first should a serious fault occur and therefore serious damage and even danger could occur?
Secondly, regardless of the type of appliance, would the vans trips "blow" in similar circumstances?
P.s. Just been to Aldi, got my spare tester at discounted price. :happy:
O
Old Soldier
Firstly,
Is DBK out there? Any thoughts on this anyone?
:hi:
May 5, 2014
671
169
Leicestershire
Beginners, got Doggy the van - March 2014
When making a revers polarity adaptor, do I need to swop the Brown & Blue cables on both end of the adaptor (the plug end and the Socket end) or only on one end?
Poohbear
280
473
Worcester
Swift Lifestlye 644
June 2015
If you do it on both ends you won't be reversing it will you. The colour of the wire is not the issue here :)
Gellyneck
9,245
18,337
More than toes wet now!
Only one end. Make sure you clearly mark it as being reversed polarity for safety's sake.
2,347
10,197
in the event of a short or overload, the fuse will blow irrespective of polarity as will the vans MCB
Regarding switched sockets.. if you have no switches on sockets... there is no problem with reverse polarity
continental vans don't have switched sockets, so that issue doesn't arise (unless someone has changed them for UK 13A switched sockets) why the continentals don't worry about reverse polarity.. also, the plugs can put plugged in either way around..
True in most cases. I had an expensive CD player destroyed by reversed polarity a few years back.
I'm surprised no-one has said this but "no you didn't". As has been said, the continentals have plugs which can be plugged either so much of the time their kit is running "reversed", it's the same kit we have.
Something else blew it.
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
On the continent they switch both L&N - so reverse polarity will make no difference.
Here in the UK we only switch L
O
Old Soldier
Interesting that because it worked in the morning at one site with normal polarity and after connecting up at the next site that afternoon, where I had forgotten to check the polarity, it didn't and it had not been moved, dropped touched or unplugged. You of course may be right, it may have just packed in but I don't take the chance anymore. :smiley:
Mar 23, 2012
9,551
32,144
sleights
c class
On a recent Motorhome guided tour I was surprised how many people did not have one of these, nor a conversion cable or device and were unaware that some sites had faulty wiring with reversed polarity. Out of the ten or so sites that we stayed in, seven were faulty and all were 4star!!, indeed, some had a combination of good and bad, even on the same electrical supply point.[/QUOTE
If you think about all the motorhomes on the continent if it was a big problem they would all be going up in smoke. We have a chausson so don't bother as all our switches are double poled
2,347
10,197
can you show me a picture, or give a link to a double poled continental socket such as you have fitted .. ?
reason I ask, I have heard about them but never seen any in a van .. or found on the net
mine are un switched.
LAM
Apr 23, 2014
415
288
Wiltshire
Chausson 640 Welcome
Began with the purchase of our first, ever MH in 2014
Just seen this advertised. Worth having with you when you go abroad let alone for home use.
Clicked on the link and it takes me to beer offers........ good but not the above item ??? :doh:
O
Old Soldier
Yes, I found that out too but since the OP was a week ago I guess the advert has changed since.
I managed to get one yesterday so they still may be in stock. :happy:
Reactions: LAM
O
Old Soldier
Reverse polarity CANNOT damage 230vac equipment and the 12v electrics are isolated from 230vac so if your equipment was damaged it was not through reversed polarity on 230v.
Sorry but I can't agree that it "cannot" happen. It did and by the way the CD player was a mains unit.
Apart from that, I still believe it better to be safe than sorry, If I switch off an Item I like to know it is switched off.
The OP was originally to advise that these testers were available and that most of the sites I recently visited in France had reversed polarity supplies, not cause an argument over the concequences or not of using R P supplies.
It's interisting that nobody bothered to say thanks for the posting in the first place, I hope it was useful to some funsters. :smiley:
Gellyneck
9,245
18,337
@Old Soldier. Correct. Most remiss of myself. I did go and get one and have been testing it out in the house.
So far so good particularly as rewired about twenty years ago.
Motorhome next.
Jun 16, 2013
1,228
820
Wiltshire
Low Profile Hymer CL 554
Since May 2014
I have a chausson 510. We bought all the reverse polarity stuff needed. But from this thread it is not needed because we have a continental van? Also if we did need it the polarity plug shows different combinations of lights how do we know when to use the cable?
Jun 16, 2013
1,228
820
Wiltshire
Since May 2014
This is my plug which would show reverse polarity ?
Reactions: LAM
