2001 Fiat Ducato...Intermittent Idle Mode...Help Please (1 Viewer)
Benimar_funbus
5
Manchester
Coachbult
5 years
I have had this problem for 18 months now and took it to a couple of garages with no resolution.
The problem is the van goes into idle mode and the injector light comes on. If I in 5th and crusing it limits it to around 50 mph and if pulling away its low accelator still the light goes out.
Sometimes is a second and sometimes is 30 secs. usually once or twice on a journey but sometimes more.
The first problem is the 2 garages I took it to could not get the diagnostic tool to work with it.
I have been advised it could be the injector cables, fuel sensor, faulty ecu etc.
So has anyone has this issue and how did they resolve it.
Can anyone recommend a garage in the Manchester area who knows his way round the fiat ducato of this age i.e 2001.
B
Benimar_funbus
5
Manchester
Coachbult
5 years
Just had a similar problem on a vauxhall movano. The problem was the EGR valve.
Thanks for your reply
Unfortunately, as I have not had a diagnostic report as the 2 garages I visiited couldnt communicate with the van's ECU, its all speculation. Fiat wanted to replace the whole ECU at a astronomical cost.
I believe the issue is that the garages have not got the right cable as the predates the new type of connector. So really need to know what cable\tool I need. Also need to find a garage in Manchester who can assist.
I presume your vehicle is of a later model\make and was not a issue to diagnosed.
Dave
Apr 21, 2009
546
35,003
East Cowes, PO32 6RU
Caravan
Caravan since 1970, motorhome or RV since 1999 then back to a caravan in 2017.
You could contact Mark (ex TBTurbo foreman) at Unit 45, Lune Business Park, Lancaster, LA1 5FT (www.candmauto.co.uk to look, 01524843721 or email info@candmauto.co.uk)
He changed the cam belt and adjusted the clutch and a few other jobs for me when I had the Hymer. Seemed very knowledgeable about all things FIAT - worth a 'phone call and not too far from you!
ShiftZZ
21,383
84,574
Dark Side of the Moon
I have had issues with the Fiat Ducatto, well documented on here.. The issue may well be the ECU, in my case it would corrupt the data leaving the ECU and that caused some of the issues. Fiat garages will be as much use as a chocolate teapot, they will sell you an new ECU. There is a further problem with FIAT, not all of their components are identical, their wiring is also a bit sus.
Secondly, you can’t get a reply from FIAT Technical and they will not admit they have issues, the UK help desk is in Italy, they will not release any technical document, even from their own webpage which offers the service for a fee and then they refuse. They also offer a recon ECU or Consul on their parts website, but, they will not allow you or dealers to buy them...
I suggest you look for an auto electrical engineer and take it from there.
Sorry I can’t help any further..
