13 amp switched socket with USB charger (1 Viewer)
ojibway
531
305
Eastbourne
Van Conversion
since 2005
Hi Funsters,
this isn't a motorhome question but I'm sure someone out there can help -
I have just installed a 13amp socket with USB charger.
After I plugged in a 'phone and an iPad I noticed it buzzed and got quite hot - hotter than I would have expected. The ordinary plug-in USB chargers don't seem to get hot.
Is this to be expected or should I maybe take it back?
The socket is from Screfix and is BG (British General).
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
I have installed several of these around the house. None buzz or get hot. I think I'd contact screwfix (I've always found them very customer friendly)
I think they are the future rather than plug in chargers.
Wyn
Lenny HB
53,448
150,063
On the coast in West Sussex
Hymer B678 DL
iPads & iPhones take a higher charging current than most USB devices, the standard for USB outlets on a computer is 500ma, Ipad & iPhones need a 1amp charger.
If the the USB outputs are built to the standard they won't cope with charging an ipad. Nothing wrong with the socket just iPads & iPhones not conforming to the standard.
You need to find one with at least 1 amp output on the USB sockets. If the ones you brought are at least 1 amp you probably have a faulty one.
I have looked at them but decided against them, as we are away more it would be something else powered up permanently another fire risk in the house.
Feb 24, 2013
13,083
101,452
Bolsover, Derbyshire
Hymer S800
not long enough
I have seen these for sale and wonder why anybody would bother to change, if doing a full room change then it might make sense, but why not just plug in the adaptor? even it that means using a multi plug
As for your fault, I would get it checked or changed, could it just be a loose connection when fitted rather than a component issue
johnp10
7,774
15,181
North Lincolnshire
8 years ish
  • We use this, from Argos, in the house and in the MH.
  • Good little gizmo, does the job.
    • 9368640_R_Z001A_UC953353
    • By Masterplug, Surge protected.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Wyn
I don't. A socket will last 100 years. The complex tiny charger circuit, crammed in, might well not survive the first thunder storm or electrically noisy old vacuum cleaner.
Puddleduck
12,385
43,990
Scottish Borders
Without at present
On and off for many years.
Ours are supposed to be 2.1 amp shared over two USB outlets. I would not charge ipad and iphone at the same time, too close to the max load. They do charge one unit fine with no heat or buzz.
I think I would send the unit you have back and get a replacement. They should not get hot or buzz.
thehutchies
1,527
1,776
The Wheelèd Shed
Hi Funsters,
It is a motorhome question because we have several of them in our van :)
Iphones and some of our tablets charge slowly but none of the sockets get warm or buzz.
Sounds dodgy!
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
some things are designed to 'buzz and get hot'.. ;)
that's not one of them.. take it back
Hmmmmmm, your lass uses one that plugs into a USB? What a good idea, where did you get it from I'll pass the info on to SWMBO :LOL:
ambulancekidd
Sep 23, 2014
10,371
28,397
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
I've had a few of these installed around the house for a while & have had not trouble. Certainly not getting hot or making noises.
ojibway
ojibway
531
305
Eastbourne
Van Conversion
since 2005
Thanks for the replies, guys.
I phoned the company BG help line and their comments were worse than useless. They suggested that they can get hot and the buzzing could be from somewhere else, resonating through the socket - where did they find the bloke? Do they even pay him? He even spoke English - proper English!!o_O
I think I will take them back and use an adaptor like johnp10 suggested(y)
Mar 23, 2012
9,548
32,107
sleights
c class
Fitted 2 no problems no buzzing I think screwfix do another make also could give them a try
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
If you are using it to charge Samsung phones or tablets they draw up to 2 amps for fast charging. I burnt out a usb charger designed for an iPhone in no time at all.
Dick
ojibway
ojibway
531
305
Eastbourne
Van Conversion
since 2005
I have just read the leaflet that came with the socket. It says it delivers 2.1A divided between the two USB sockets, so I was overloading it, hence the heat! But buzzing?
And why couldn't the guy from technical support have told me this?
And why are they making something like this that doesn't properly support ALL common devices?
ambulancekidd
Sep 23, 2014
10,371
28,397
Ayrshire Scotland
Swift Kon-Tiki 640
The issue seems to be that USB connections & chargers run at different rates & amperages. Its totally weird, you'd need a slide rule & a ready re conner to know which ones to use.
Then you come across two different types of USB connectors on some PCs etc. My notebook has two different types, an old type & a new type apparently. The difference is the speed of data transfer!!
Jul 1, 2010
3,204
33,557
SW Northumberland
Hymer B 588 DL
Since September 2010
Have fitted 2 in the house, after a bit of research and asking an Electrical retailer was advised to purchase Deta USB outlets, not the cheapest at around £17 to £18 a pop but as in life you get what you pay for. The two usb outlets have differant ratings and as such are marked up "phone" and "Tablet" Data sheet attached. Broken Link Removed
Jul 1, 2010
3,204
33,557
SW Northumberland
Hymer B 588 DL
Just to add we have been charging an Ipad Air and a Samsung Galaxy Tablet both 10.1 inch models from the same Deta socket with no overheating, buzzing or whatever for over 6 months now
Aldi sell them now and then. Double and single sockets. Are you sure the iphone does not want lots of amps and the socket only pumps out a handfull?
Minxy
32,659
66,565
E Yorks
Carthago Compactline
Oooo ... you'll be in trouble now ... suggesting that Apple devices are COMMON!!! I can hear the teeth of iPads owners etc grinding their teeth from here!!!! :D
Minxy
32,659
66,565
E Yorks
I used to tell them at work that when they shut down their computers etc to turn them off at the wall socket, and not to use the switch on the machine itself ... a 'bust' socket was much easier to have replaced and cheaper!
Aug 10, 2012
839
891
cambridge
Globecar
since2001
What you need is one of these
The most fantastic thing in the world ever,..........
OK no quite , but its good
You can get all your charging in one place, we moved everything to one worktop
Got mine from amazon, they are the best selling charger in the USA
If you go abroad you just get a new lead/plug
Broken Link Removed
Minxy
32,659
66,565
E Yorks
Maybe one of these would do?
Broken Link Removed
Puddleduck
12,385
43,990
Scottish Borders
Without at present
You have to be very careful about the total power draw from the device.
I can charge my tablet from some (not all) multi-devices as long as it is the only item drawing power. I can charge phone, camera, mp3 player all at the same time as they don't pull so much power. Still worth having the multi-charge device as I can charge several low pull items or a single big power puller - rather pack one device than several.
