12v Xmas lights? (3 Viewers)
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
We've got a 12v external socket to connect a water pump to refill the onboard tank.
Anyone know if I can use the socket to run some Xmas lights from?
This would be a once off as we normally like minimum lighting around a site but as we will be away for Xmas, why not.
Any recommendations on where to get a string of 12v Xmas lights?
Cheers
2dogs
Sep 26, 2013
4,172
5,159
Market Rasen
Since 2003
We have the ones that come with a small solar panel, quite cheap and usually top up during the day and last a few hours at night.
Mike
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Mike, may take a look at that, just thought as the socket is on the van and I don't use it to fill the water tank I would try that option.
Trikeman, I would assume if I only want static lights I could cut off the control box and wire it direct with the plug I have to the outside socket.
Cheers
2dogs
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Cheers
2dogs
Not too sure about that - I think the controller would have some sort of transformer, as generally the little LEDs run on a lot lower than 12v direct. We had some for the kids parties and I cut the end off the plug and put a pair of crocodile clips on (just quick way to the battery) and that worked a treat but still the controller was on there. Ours has a 'on' mode where they all just stay on and not flash or dance about - they are quite bright for what they are.
hope it helps.
Regards,
Trikeman. :winky:
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Trikeman,
I could do the same but use the plug I've got instead of croc clips.
Cheers
2dogs
Armytwowheels
6,476
14,883
Market Harborough
Carthago S Plus - Iveco
Since 2011
We have the same as the ones in the ebay link and wire them into the 12v supply in the fridge vent. No reason why putting a socket on and using your external point should be a problem.... So says Colin. The remote control allows you to choose between static for flashing, or colour changing lights.
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
I hope so .... just put an order in.
and I just thought, as the van is always plugged up at home, I could hang the lighting from the van on the house guttering when we get back:thumb:
that'll keep her happy::bigsmile:
Cheers
2dogs
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Cheers
2dogs
you could but look around you can get the same lights without the control for half the price.
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Wildman,
went for the control as when at home I can flash all I like:Eeek:
just don't want to disturb next door on site::bigsmile:
Cheers
2dogs
17,637
43,375
one point is that the pump socket on many vans is not permanent live. on mine the switch for water pump has 3 settings, internal pump for taps, off and external pump for filling the tank
years ago we used to go to the c&cc national feast of lanterns and the local region one. we all added lights and a theme to our vans. wonderful displays they were
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Big1,
control panel in the van has pump on/off, don't even know if outside socket works yet but assume it is permanent on, will let you know how I get on.
Cheers
2dogs
dogman
549
440
chepstow
Coach Built
I'm a newbie
Just ordered two from E bay, cheap enough aren't they, thought I would fit cigarette light type plugs on them since I have wired in a 4 socket gang direct from the leisure battery and mounted them on the panel behind the passenger seat. I can then run the leads through the partly opened window (for ventilation) which would be somewhere handy for the job.:thumb:
So many things come with that type of plug now such as sat nav, phone charger, etc. I thought extras would be useful, also a handy spot to plug in the TV when not on EHU without cables being draped all over the place.
Cal
