12v Xmas lights?
Discussion in 'Motorhome Chat' started by 2dogs, Nov 30, 2013.
  1. 2dogs
    2dogs Read Only Funster
    Nov 2, 2011
    257
    73
    Devon
    We've got a 12v external socket to connect a water pump to refill the onboard tank.
    Anyone know if I can use the socket to run some Xmas lights from?
    This would be a once off as we normally like minimum lighting around a site but as we will be away for Xmas, why not.
    Any recommendations on where to get a string of 12v Xmas lights?
    2dogs
  2. Mikeco
    Mikeco Funster
    Sep 26, 2013
    642
    435
    Market Rasen
    We have the ones that come with a small solar panel, quite cheap and usually top up during the day and last a few hours at night.
    Mike
  3. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    • Like Like x 2
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    no good reason why you shouldnt use the socket.
    its probably rated at 10amps for the water pump.
  5. 2dogs
    Nov 2, 2011
    257
    73
    Devon
    Thanks Mike, may take a look at that, just thought as the socket is on the van and I don't use it to fill the water tank I would try that option.
    Trikeman, I would assume if I only want static lights I could cut off the control box and wire it direct with the plug I have to the outside socket.
    2dogs
  6. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Not too sure about that - I think the controller would have some sort of transformer, as generally the little LEDs run on a lot lower than 12v direct. We had some for the kids parties and I cut the end off the plug and put a pair of crocodile clips on (just quick way to the battery) and that worked a treat but still the controller was on there. Ours has a 'on' mode where they all just stay on and not flash or dance about - they are quite bright for what they are.
    hope it helps.
    Regards,
    Trikeman. :Wink:
  7. 2dogs
    Nov 2, 2011
    257
    73
    Devon
    Thanks Trikeman,
    I could do the same but use the plug I've got instead of croc clips.
    2dogs
  8. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    :thumb:
  9. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,064
    6,590
    Spain for the winter
    We have the same as the ones in the ebay link and wire them into the 12v supply in the fridge vent. No reason why putting a socket on and using your external point should be a problem.... So says Colin. The remote control allows you to choose between static for flashing, or colour changing lights.
  10. 2dogs
    Nov 2, 2011
    257
    73
    Devon
    I hope so .... just put an order in.
    and I just thought, as the van is always plugged up at home, I could hang the lighting from the van on the house guttering when we get back:thumb:
    that'll keep her happy:BigGrin:
    2dogs
  11. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    you could but look around you can get the same lights without the control for half the price.
    • Like Like x 1
  12. 2dogs
    Nov 2, 2011
    257
    73
    Devon
    Thanks Wildman,
    went for the control as when at home I can flash all I like:Eeek:
    just don't want to disturb next door on site:BigGrin:
    2dogs
    • Like Like x 2
  13. Armytwowheels
    Aug 10, 2012
    4,064
    6,590
    If it is the same as ours the colour changing mode is lovely and slow.
  14. 2dogs
    Nov 2, 2011
    257
    73
    Devon
    hmm ... slow flashing:Eeek: ... I'll try anything once:BigGrin:
    • Like Like x 2
  15. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,357
    9,807
    one point is that the pump socket on many vans is not permanent live. on mine the switch for water pump has 3 settings, internal pump for taps, off and external pump for filling the tank
    years ago we used to go to the c&cc national feast of lanterns and the local region one. we all added lights and a theme to our vans. wonderful displays they were
  16. 2dogs
    Nov 2, 2011
    257
    73
    Devon
    Thanks Big1,
    control panel in the van has pump on/off, don't even know if outside socket works yet but assume it is permanent on, will let you know how I get on.
    2dogs
  17. dogman
    dogman Read Only Funster
    Oct 24, 2013
    551
    444
    chepstow
    Just ordered two from E bay, cheap enough aren't they, thought I would fit cigarette light type plugs on them since I have wired in a 4 socket gang direct from the leisure battery and mounted them on the panel behind the passenger seat. I can then run the leads through the partly opened window (for ventilation) which would be somewhere handy for the job.:thumb:
    So many things come with that type of plug now such as sat nav, phone charger, etc. I thought extras would be useful, also a handy spot to plug in the TV when not on EHU without cables being draped all over the place.
    Cal
Similar Threads
  1. plumber54
    4
    223
  2. emilu
    20
    795
  3. Big bus man
    21
    647
  4. landyman
    19
    881
  5. lorger
    14
    902
