12v Problem ..... (1 Viewer)
John Lesniak
5
Wolverhampton
Lunar
when hooked up, all electrical appliances work fine. When disconnected and travelling, radio / CD player will not function at all - leisure battery drains as it runs the fridge. All help greatly appreciated.
Regards to all, John
MattR
4,105
38,900
Beds
Panel van
Years
Not an expert on this but is the supply from the alternator to the leisure battery charger live when the vehicle is running? Sounds like the lb is not being charged when running; lose wire? Fuse? Switch? Duff charger? Duff battery?
No idea why the radio does not play when not connected to mains.
J
John Lesniak
5
Wolverhampton
Lunar
Hi and thanks for quick response.
It is annoying because we are on our travels - a great time for things to go wrong !
Thanks, John
Dec 12, 2010
5,414
21,584
Cumbria
One of the electrical experts will be along shortly with some useful info if you let us know what model van you have and a little about it's history. Sounds like your split charge relay might have failed, but your fridge shouldn't be wired direct to your leisure battery regardless. :(
Dec 27, 2014
967
3,361
Strange one this.
Your fridge should only run when engine is running and is switched usually thru a relay.
Likewise your LB's should charge thru a split charge relay when engine is running.
Both circuits should be separate.
Is it a factory built ? Or is it a PVC?
Someone may have done a repair at some point by wiring the fridge to the split charge relay, this shouldn't be done as the fridge can draw current then from the LB's then..... not good.
The radio should not have any connection to the LB's.(assuming it's the dash radio)
Need more info I'm afraid.
Vehicle type/year/conversion or not?
J
John Lesniak
5
Wolverhampton
Lunar
Thanks for the suggestions. Where is this relay normally installed ? We have a Lunar 5 Star on on Renault Master chassis.
Regards, John
J
John Lesniak
5
Wolverhampton
Lunar
Hi to everyone and thanks for all the advice. Problem resolved with the leisure battery now replaced.
Regards, John
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
maybe, maybe not, it all depends why the battery was knackered, bad charging or old age. You now need to subscribe to post again.
Jul 12, 2013
3,872
5,275
The City of Henlow
Adria Supreme
Since 1980
Keep you eye on your new battery, if the fault was caused by the fridge drawing power from the LB, there could still be the problem. On the bright side, I am guessing that you have had this checked out when the battery was changed. Have a good trip from here on.....
Alan
