NorthernSands
Hi all.
Our x230 heater & A/C blower isn't very powerful. It makes all the right noises, suggesting the resistor pack is OK, and sounds as though it should be powerful, but it isn't.
I expect the fresh air route to be hindered by the gubbins that Hymer put over the air-intake (from where the scuttle panel used to be to behind a headlight) and, although re-circ is better, it isn't much. Using the lever that operates between re-circ and fresh air sounds as though the vane is behind the dash, so I can't see a blocked pollen filter causing the problem (which is behind where the scuttle panel was).
Anyone any ideas?
Many thanks!
Peter.
Anyone any ideas?
Many thanks!
Peter.
