- Jul 8, 2019
- 301
- 134
- Jap Import Nissan4x4
- Semi-newbie to motorhomes
Hello,
My new diesel heater has E8 error and fuel is not getting pumped into it even though the pump is clicking and attempting to....can anyone help:
Backstory:
As my old Mikuni MY16 diesel heater had an issue it was cheaper to replace it than fix it.
I bought a 5kw Vevor chinese one and want to run it from my main diesel fuel tank. Also I saw people saying this rubbery green hose they supply you with is not very good and its better to use the hard nylon hose that has a smaller bore hole because the fuel pump finds it easier to push the fuel through.
So I thought i would be clever and simply take the higher quality nylon hose off my old heater and plug it onto the new one. The metal ends of the fuel pump were larger on my new heater so i ran a length of green hose over that and the nylon one. I have many areas of air inside the hose which I can see, but the pump is clicking but still not pumping the fuel through, lik its too weak, or maybe theres a blockage, but im just making guesses.
To what extent are these chinese heaters gravity-fed? The current set up ive installed takes the diesel by splicing from the main fuel line which runs on the top of the fuel tank, so I dont have a line that goes down inside the tank so to speak. It worked fine on the old diesel heater. Thats how they installed it.
How to remove the air bubbles?
Backstory:
