Windscreen Electric Blind Emergency Crank?
DethleffGlobetrotter
Started in 2005, then took a 15 year break, back in 2022
Maybe I'm stupid, but the manual for the Dethleffs states this:-
I can't for the life of me see where/how you would manually wind the blind.
I assume the electric blinds are common across many motorhomes.
Anyone care to share where to manually crank if the motor fails?
Cheers,
Steve
OK, maybe I should drop the bed and take a look, it's certainly not obvious as is. Cheers.
On our LV, there is a small grill just above the blind on the LHS, remove this, and there is an allen key fitment - be patient it is very slow.
Lenny HB will know I think he posted on a previous thread about it🤔
When our blind stopped working on our LV, hubby pulled the fuse out that was behind the grill and popped it back in. That reset it.....for now. Might be worth a try if it's not working, otherwise it could be like ours, a hole that takes an allen key
Does this help? Looks like the manual crank is behind the cover - if this system is the same as on your van.
Here is a photo of my crank arm.
You need to take the curtain around the bed down and it fits in the opposite end to the motor.
we never got a crank handle with our van Lenny hope I don’t ever need one though🤞🤞🤞😬
Nor did we, hence why I had to use an allen key.
Should have done I think ours was just lying in the garage. I've stored it under the drop down bed mattress.
