What type of fuse is this ?
Graham of Madrid
Mc Louis Glamys 40
Since 2019
Hello again !
What type of fuse is this please ? There appears to be a cover on it didn't want to come off straight away. Before I go and have another go, has anyone seen one, is it just a regular auto fuse ?
Thanks in advance.
Probably just an ordinary spade fuse inside it (y)
Agreed, standard spade under the cover.
A little flat blade under each clip on the sides will pop the top off.
As all of the above, clips are on the side for removing the cover, but I think it might be a maxi blade fuse, larger than a standard blade fuse
Cheers. Good advice, I'll lever off the plastic cover and have a look. Was just worried that I might disrupt/break something.
If you look on eBay for inline fuses you will see how they work. Just put 2 in my battery master. Cheap as chips
