Blimey.. at that price I think I'll stick to using my nose and hands..Protimeter Aquant Non-Invasive Moisture Meter BLD5765
TIA
Hence why I’m reaching out! My pin version was around £20-30 and works well except for the pin marksBlimey.. at that price I think I'll stick to using my nose and hands..![]()
It was explained to me that the pin less ones are fine on bare wood or dry wall, if the area is painted or covered in a plasticised covering it won't show a damp area. And that is what it does shows a damp area, where as the pin type will pin point it (sorry for the pun).
I think that somebody has been tugging your chain,the pinless one I have works just fine on the surfaces in our van, although it will go a bit bananas if it gets too near metalwork.
MO57: Pinless Moisture Meter | Extech Instruments
MO57: Pinless Spherical Sensor Moisture Meter for Non-Invasive Measurements on Wood and Other Building Materialswww.extech.com
A pinless one will be hopeless on a laquered or painted surface. If you think about it that must be true.
They work by calculating the lack of resistance to the flow of electricity . A pinless one works by calculating the flow across its surface, but if the surface is not representative of what's underneath then it's meaningless. It will work out the conductivity of the surface only. That's fine on bare wood.
I would stick to the one with pins. Yes they do penetrate the surface slightly but you will get a proper result. In terms of damage, so long as you are not doing it every day it will take years and years to damage the surface to a degree that you would notice.
Yes it does. How much are these. Can you select the depth of the measurement you want to see.
I Use a piece of wood that has been outside in the rain, and another that has been kept in the dry to get the 100-10% calibration ....I have one of these: https://uk.farnell.com/tenma/ten01072/moisture-meter-pinless/dp/3409785
I have used it for years on many different projects around the house and motorhome and have no bad things to say about it.
You can pay anything from £30 to £300. The thing to remember is to calibrate your tool for the environment it is being used in. So, first you need to obtain a datum measurement. This can be done by taking several readings from surfaces that could not realistically be damp, internal panels etc. This will be your base line, so anything above this will need investigating.
Geoff
It's the Extech MO57 that I have and I bought it 3 or 4 years ago from CPC.
CPC still stock them and appear to be the best price as well.
https://cpc.farnell.com/extech-inst...r-pinless/dp/IN07923?ost=extech+mo57&cfm=true
It basically is telling me what the moisture level is in the area I'm testing, but I like that it's easy to move it over the surface to give you readings to indicate the dampness and pinpoint the highest reading as the likely point at which water is getting in. Fingers crossed that I have not found any levels of dampness to worry about in our van to date.
I accept that the Extech MO57 is not cutting edge for the money, but it will tell you if you have a problem.
Here's the user manual if you want to cast an eye over it.
