What exhaust bracket
moggyg
Scotland
Ace Firenze 2007
newbie - again
I have a Fiat ducato 2007 and when I got it, it had a plastic cable tie holding the exhaust up. What do I need to buy? A metal cable tie?
Cheers Marco
You need a pipe clamp same diameter as pipe and a flexible (rubber) mounting to bolt to the chassis. You should be able to get them from a motor-factors or halfrauds.
Hope this helps,
Cheers, Dave:xsurprised:
If you search for 'Exhaust pipe hangers' you should find plenty, take your pick...
That doesn’t look like an exhaust bracket place, I suspect the mounting for the exhaust is further under the body and you may find the point there and the appropriate place to fix it...:xThumb:
I agree: examine existing mounts for sag - you should not need one that's visible.
There isn't usually a mounting for the exhaust at that position. The system is supported at each end of the silencer and the "tailpipe" is self supporting off the exit of the silencer.
D.
Cheers all. I will get under the van to take a look first dry day here .... June/July next year!
Ciao
Marco
