- Jun 7, 2021
- 3
- 2
- Don't own one yet
So I’m travelling through Europe at the moment and my water heater has started leaking from the pressure relief valve… I didn’t do the installation myself but have a pretty good understanding of the system. It seemed fine for the first few weeks of the trip, but now at a month in when I fire it up it just starts pouring from the relief tap, I’ve been on the phone to propex and they mentioned it needed to be a 20psi pump, which it is so there shouldn’t be any “over pressure” there. Trying to figure out what else might be causing it and what I can do to try and help it? Unlikely to get it fixed out here so we’ll aware it may be cold showers for the rest of the trip but if any of you pros had any ideas I’d be eternally grateful! Seems odd for the valve itself to go bust, the heater is basically new and we’ve not been using it much on the trip.
My next step was to switch off the pump and drain the heater I think just to see if that helps it out?
Thanks in advance for any thoughts on this!
