Water filter system
Fleetwood, UK
a class frankia
Does anyone know of any built in water filter systems that I can add, so I can use the generous sized water tank for drinking water. Seen some on american Van's with a separate tap.
Check eBay for a 10 inch water filter housing. Industrial size with a wide range and types of filter cartridges
Its looks like the sort of thing I am looking for. Would you say its suitable for mh, would you run a separate line from the water pipe or just incorporate into existing system. I wonder if it filtrates viruses and bacteria. I will look more into it. Thanks
Ive been using one of these for the past year, very pleased with it. Used it in Spain, Portugal, etc although havent given it the Morocco water test yet.
We have had a Pozzani system fitted for a number of years.
They now use this replacement filter.
Heres the filter options. 1 micron filter sounds right for "bug" removal but i am no expert. I would T it off an existing pipe but most likely need an adaptor as the standard kit has one of those screw on "puncture the copper pipe" style fittings. I did call them a long time ago and they had extra accessories to suggest.
<Broken link removed>
We have the 3M system Pozzani supply and really happy with it.
Fitted it into a few other peoples vans as well, with no complaints,
Can you recommend a nice adaptor or connector as I will be going from a clear plastic pipe (American) rather than copper pipe.
