Waeco CCF40. red light of doom!
South Lincolnshire
Converted Renault Master
6 years
Anyone know about these compressor coolboxes? On mains it'll turn on and the fan runs for a minute then cuts out. Compressor then restarts and then the fan restarts in a continuous cycle. Red light flashes once every 5 seconds (which I believe is low voltage warning so it shouldn't really). It doesn't seem to get cold. No heat from heat exchanger grills either. I havn't tried it from a leisure battery but it won't run from a 12 volt 5amp switch mode power supply connected to the 12v power socket (it should do really as its rated at 4 amps on 12v.
