Compactliner
- May 30, 2020
- 204
- 184
- Carthago Compact 138
- 11 yrs
- I am looking at changing my current solar controller (simple dual charge 10A PWM unit) for a Votronic...i have a single 100w panel and may add another so will go large enough to cope.
my current system has +/- wiring pairs from panel to controller, from controller to leisure battery and from the controller to the vehicle batt.
all connections are suitably fused.
looking at the wiring diagram for the Votronic, the panel to controller connections are fine.
the controller to leisure batteries (BORD I) is also fine...positive goes to "+BORD I" and negative goes to "- I+II"
the diagram also shows the leisure batteries having its own normal earth plus the negative returning to the controller.
However, despite the Votronic having the above negative slot marked "- I+II" the diagram doesn't show a negative for the vehicle battery returning here, just a chassis negative.
obviously, with a new install, (possibly) only the positive would be fitted...however, i have a pair from the vehicle battery and would have to 'do something' with the negative wire.
looking at the markings on the Votronic unit, why wouldn't this go into the "- I+II' connector?
i spoke to Roadpro about this and they said to 'tape off' the vehicle negative as this battery already has a chassis earth and that a failure here might then use 'my negative' as the earth which not be of sufficient size....but why is the negative socket marked for "I+II" if only the leisure battery (BORD I) should be connected?
i posted on another forum and the resonse was 'do as roadpro' (and the votronic schematic) says...
ive also looked at the Epever Duo Racer but this shows both positive AND negative connected to the cab battery.....
however, it has a 'grounding terminal' and this description in the manual..
Step3:Grounding❹
DR N series is a common-negative controller, where all the negative terminals of PV array and battery can be grounded simultaneously or any one of the negative will be grounded. However, according to the practical application, all the negative terminals of PV array and battery needn’t to be grounded, but the grounding terminal on controller’s shell must be grounded, which may effectively shield the electromagnetic interference from the outside, and prevent some electric shock to the human body due to the electrification of the shell.
_________________
Chris.
Carthago C-Compactline i138
bolero boyMember
Auto-Sleeper : Carthago Compactline
Vehicle Year : 2017
_________________
Chris.
bolero boyMember
Vehicle Year : 2017
LIKE
