VB-Semiair (1 Viewer)
The Returnee
149
113
Togo
In 1983 I drove from England to Lomé
I hope that my plan to put a Piaggio MP3 in my garage works out before Christmas. They are not the lightest of machines which is why I'm considering VB-Semiair.
Although not in the brochures, I've read somewhere that around 150mm (6'') of lift is possible and hope that might be an easy way of levelling up on pitches which aren't level. An extra benefit.
Does anyone have experience of the Vb-Semiair kit?
Thanks, and Merry Christmas - in case the internet slows down.
Sep 7, 2010
776
4,042
cardiff
Frankia 7900 Platin plus
since 2010
VB semi -air. Best addition to my sprinter based A class. Can be of ,limited use to level, but main benefit is ride quality. Impressive improvement - much less roll, sway when passed by big trucks and improved confidence.
Only downside apart from cost (and small weight) is fuel consumption as tempted to drive 10 mph faster as so much more confident.
Jul 29, 2013
8,839
16,042
Salisbury
Hymer B678DL A class
since 2011
Had VB SEMI on our Exsis to give more stability when towing, it certainly won’t lift an extra 150mm I could get about 50mm at most.(y)(y)(y)
Buster30
90
32
Derbyshire
Hymer Mercedes ML580
Since 2018
I fitted the Dunlop system from Airride to my Merc/Hymer at the weekend, very easy fit, not tried it yet but taking it to have tracker fitted so will see what it’s like on the motorway tomorrow
Blue Knight
5,232
5,709
Durham
Globecar Summit 640
3-bar pressure raises a typical 3.5T van by 21mm and every bar thereafter by 6-7mm up to a max of 6-bar total.
.......so in theory you should achieve a circa 40-42mm raise at the maximum permissible pressure.
Hope this helps,
Andrew
Nov 17, 2012
1,929
2,643
WEST SUSSEX
HYMER B SL 674
SINCE 2005
I had the VP Semiair system fitted on my B544. terrific ride, great for getting on and off ferries - particularly Italian, but no use for levelling on a pitch. Still worth it though. Go for it.
The Returnee
The Returnee
149
113
Togo
Thanks folks. Definitely going to have it fitted.
Mr Chrysalis
2,364
296,895
Lincolnshire
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
Semi air makes a huge improvement to handling but negligible value to levelling
