Realist
- Nov 4, 2018
- 1,747
- 2,667
- Caravan: Buccaneer
- Caravan before 2000 / Motorhome From 2018 to 22 / Now Caravan again.
Hi all,
My Strikeback is beeping 4 times on alarm eddievanbitz when all doors are closed, checked each contact with a magnet and it still beeps.
I’ve had a quick look at the Door contact itself to see if I can access the rear screws so I can bypass each contact and test that way but they look sealed up.
So does anyone know if they are none accessible or are they ran to a central point where if I can access I could bridge and test each contact.
Apart from closing each door, testing with a magnet and not having the huge urge to rip a contact apart and most probs break one.
I have a bike loop and yes the switch is down off and I’ve also plugged the loop in and tested again with the switch up and down.
Did call VB and chap I spoke to set run through their FAQ and any issues to contact them but I work Mon to Fri and don’t get home till 5 so it’s to late to call back.
Plus long drive if the van needs to go back in after only 12 months.
Regards.
Regards.
