JimmE
I've been meaning to start writing this up for a while. The upgrade is now well underway, so figured it's as good a time as any to get started on the writeup! Hopefully some of this can be helpful to others considering similar, but as usual - this is how I chose to go about it - not necessarily the 'best' or 'right' way to do it, and certainly not the only way! That said, I try to do things to a high standard - albeit also have a tendancy to over-think things sometimes - so hopefully anyone with more knowledge/experience than me won't find anything here too horrifying!
Background
After purchasing our van last year, we've been researching installing an inverter and associated power system sufficient to run a "low power" (900w) hairdryer and a pair of GHD hair straightners - my OH still won't be without these on a trip! Whilst it all works fine on hookup, that has limited our choice of sites on a number of occassions. On other occasions, even at a site with EHU, needing to be on hookup has limited our choice of pitch and meant we've missed out on a few pitches with great views!
We've had the van a little over a year now, and have had about 35 nights away. At present we tend to 'tour' rather than pitching up in one place for a week, so move every couple of nights and use the van to travel out to see places during the day. So, flexibility of site and pitch is useful as we're always looking for sites at short notice, rather than booking pitches weeks/months in advance. Others may have different preferences, and so different requirements.
When researching the upgrade, I saw lots of posts here and elsewhere from other people looking into the same (going back 12+ years) but few end-to-end posts covering the research, purchase and installation with any follow notes on how it worked out, so that's what I'm aiming to do here. As per another thread I posted a couple of months ago, whilst there are other threads detailing B2B installations, battery upgrades etc on lots of different vans, I've seen far fewer detailed posts on installation process in a PVC, as opposed to larger motorhomes.
So, to spec out and price up the kit required, first step was to figure out how much power actually needed to run these two appliances. It is easy to see the rated power of the hairdryer, but not the GHD straighteners. I suspected the straightners would use less power (and would be 'bursty' rather than 'continuous' but also that they appear to have electronics in them rather than being straightforward electric appliances, therefore assume they would prefer/require a pure sine wave inverter, rather than the cheaper modified wave inverters. Going for pure sine wave also means we can use it to run other electronic appliances in the future if needed.
Power requirements
First observation is that our actual power usage in the van appears minimal. We have never yet used the TV, so the main power draw is the compressor fridge. We installed a Victron SmartShunt shortly after buying the van, which has a small solar panel on the roof. Even in November, we didn't see our usage (estimated in the Victron app) drop below 89% any evening, whilst running the Truma gas heater (fan is battery powered!) and lights etc, so our existing 90ah lead battery and the onboard Sargent split-charge system with the small 80w solar panel and PWM controller appear sufficient for most of our requirements, other than the inverter.
So, how much power do we actually need to provide at any one time?
The travel hairdryer is rated at 900w, but I suspected that like a Microwave, this is the 'heating power' rather than the 'total appliance power draw'.
GHD hair straightners - I could not find any reliable information online or on the straighteners themselves to indicate how much power is required.
Therefore, I decided to buy a cheap 'clamp meter' so that I could measure the power draw of both appliances, when running over 240v. This is a meter which allows you to measure the current being drawn without having to connect an ammeter 'inline' with the circuit. I purchased this meter back in October last year, and it cost £30 delivered - I notice the price has since increased!
Current travels in a circuit - put simply in mains electricity you have the live and neutral connector inside a cable and power comes 'out' one cable and 'back' through the other. Therefore simply putting the meter around the appliance cable is no use as the live and neutral current (in opposite directions) cancel each other out, so you need to split the cable and measure just one. I didn't want to split the cable open on the actual appliances so made up a short fly lead with the outer insulation removed for a short section, to allow me to clamp the meter around just the 'live' (brown) wire, with no bare/live copper exposed.
This worked well, and after taking several readings I came up with the following figures:
Hairdryer - fused at 5A. Max current observed - 4.1A. This was fairly constant.
Straighteners - fused at 3A. Max current observed - 3.1A. This was only a peak - generally it was a little lower, plus cuts out almost entirely when up to temp.
Using the formula from Watt's law (P=IV) we can calculate the wattage, and then the number of amps which would need to be drawn to provide that same wattage from a 12v inverter rather than 240v mains.
Hairdryer - 4.1A x 240v = ~980w contstant
Straighteners - 3.1A x 240v = ~750w peak
So clearly the hairdryer has the highest power requirement. Converting that back to 12v, we can see the current requirement:
Hairdryer - 980 / 12 = ~82A
Straightners - 750 / 12 = ~63A
However, inverters are not especially efficient. Whilst I have a tendancy to 'buy once' I had already done some research and seen that 'good quality' inverters were a lot of money - in this case we were looking to do this on as much of a budget as possible, so I was looking at the 'unbranded' imported pure-sine inverters on Amazon. On that basis I decided to assume the worst, and work on a 20% inverter overhead. This is almost certainly OTT but calculating for this should mean no surprises and a bit of a margin - I don't want to be running the inverter (or any component) at 98-100% capacity all the time.
So, adding the 20% overhead shows that we need a ~1200W inverter and that we'll be pulling ~98A from the batteries and through the wiring.
To be continued!
Background
Power requirements
To be continued!
