For a non CP tyre I think 79 is far too high.I’ve got these fitted to our 2012 Bailey 620 and I’m running the fronts at 65psi and the rears at 79psi. They replaced the Michelin Agilis Camper fitted when we bought the van in 2016. They’re markedly more quiet and so far have performed pretty well in the wet and dry but have yet to try them in ice/snow.
It is what the Michelin technical chap told our garage when we ordered the tyres.For a non CP tyre I think 79 is far too high.
If its a Motorhome Michelin always seem to quote 79 regardless of axle weight.It is what the Michelin technical chap told our garage when we ordered the tyres.
I think, from Michelin’s data sheet, they consider that it is a CP tyre. I attach this.For a non CP tyre I think 79 is far too high.
I run Toyo winter tyres fronts at 56 psi axle load 1930 kg, rear 69 psi axle load 2300 kg.
Hi anyone running Michelin Agilis Cross climates? 215/70 R15 tyres what pressure are you putting in? 3685 ton MH.
That chart is for a Cross Climate CP no mention of CP's on the original post.I think, from Michelin’s data sheet, they consider that it is a CP tyre. I attach this.
But you’re right that Michelin almost always say to run the rears at 79 or even 80psi. I don’t profess to be an expert; I rely on the garage and other experts.
I would go to 72 rear 62 front, thats what I run my 4.5t on Agiois CP tyresThanks everyone, going to try 79 rear 65 front and see how it feels.
That is one heavy van!Hi anyone running Michelin Agilis Cross climates? 215/70 R15 tyres what pressure are you putting in? 3685 ton MH.
Is on those tyres.That is one heavy van!
We have camper tyres on and told to put 70 all round.Hi anyone running Michelin Agilis Cross climates? 215/70 R15 tyres what pressure are you putting in? 3685 ton MH.
Are they Michelin Agili?I have on an Autotrail Delaware - GVW 4500kg, but never running fully loaded. 225/75/R16. 121 load index - I run fronts at 55psi and rears at 72psi.
I worked out the % load against the max load on each tyre, and used the same % against the maximum tyre pressure.
Thank you for this. Using the last weights when we went to a weighbridge as follows:![]()
Motorhome Tyre Pressure Calculator | TyreSafe
Our motorhome tyre pressure calculator gives you the correct pressures for your motorhome. Check your tyres regularly for your safety.www.tyresafe.org
