Tyre pressure
Newbie
Dose anyone know the tyre pressure for a tag axle Fiat Ducato 2015 tyre size 225/75r16cp
The best course is to work out your maximum axle loading and consult your tyre manufacturer's tables. This will be typically more accurate that the vehicle manufacturer's recommendation.
  • Informative
Reactions: f6c
Ours is 54/68.
Ian
Have front and rear axles weighed then contact tyre company and they will give you correct pressures, normally you can get an answer over the phone.
colyboy
Ran ours with 60 front 72 rear... but that was based on Michelin advice after emailing normally fully loaded axle weights.
