Trying to find this Plumbing part
Dethleffs Esprit
Since 2012
Hi, I’m trying to locate this joint. It sits on top of the clean water tank and feeds the water pump, I believe it’s an 11mm connection. Any ideas where I can purchase one please. TIA
are you sure its not 12mm? John Guest do 12mm pipe connectors if it is
An aquarium or pond supplies place will have one . It will be 10 or 12mm.
Thanks. Now you mention, It might be 12mm, it’s an age thing. The name of the fitting is what I was told, but when I tried to search for that exact part I couldn’t find one.
Thanks, I did have a look there previously but I could not find an exact match, I might try to email them with a picture.
This is the sort of thing your after (but obviously in a different size). Have you checked that both of your pipes are the same size?
I am only going from what Pullingers told me when they identified the pipe was an issue, but I believe they are both 12mm.
a 90' bend with a barbed pipe connector might provide a solution?
Actually, the one in the picture above might not be any good if you have the softer coloured pvc type pipes as it doesn't have the metal grippy teeth inside.
Looks like a Reich fitting . John Guast don't seem to do a 90 degree elbow with a barbed stem. The one shown previously won't do it as it's a stem that will fit inside another 12mm fitting and not go inside a hose
I think your picture is a Reich Uniquick nozzle
