Towing module .?
Southport, UK
pilote,g740
since 2019
Hi is this the a towing module ? And should it be lit up all the time , and it seems to click randomly.3 clicks ..not sure if it should do this or not...thanks
and its in a 2018 autotrail
Well that's what it says on the label 'road lights & towing control unit' 👍
hi thanks couldn't see it till i put it on the pc ,,
VLM5 (LED road light electronic control unit - Motorhome)​
all i need to know now is should it be clicking randomly ,,?
No idea,you can download the pdf. instructions from the Sargent website or give them a ring,usually very helpful.
With no light board, trailer or caravan connected, you occasionally see a random flash of the rear indicators. This can be caused by a false trigger of the trailer detection / learning process. On some vehicles a change was made to the high-level brake light which in some cases can cause this problem. A software update is available for the VLM5 to correct this issue. Make a note of the software number on the unit and then contact Sargent support for more information and advice on how to update the unit.
just found this on Sargents website,, apparently i have to take it to an autotrail dealer to get it updated ,,
