Toilet question
Halesowen
Niesmann Bischoff
Hi all does anyone have one of the porcelain Thetford toilets where the wash jets both ways from the back. The question is can you up the flush pressure? Ours only seems to wash 3/4 of the way around the bowl, the vans flat so it’s not that. It’s a pain the front isnt getting cleaned right an you have to tip a cup of water down.
The flush will be from the main cold water supply and you will have a pressurised system, it might be possible to raise the cut off pressure of the pump but be aware that it will affect the whole system hot and cold.
It’s a new van I believe so I’d put a note on your snag list and let them sort it with the rest of your niggles/issues
