Tie down ideas for garage ?
beachcaster
east sussex
a few years
I have a Auto-Trail 690 G
On the floor of the garage are two rails with ajustable sliding anchor points.
But there are no anchor points on the walls.
Anyone have a neat solution for this.........to tie bikes and boxes down securely etc
I am also going to have to make up a bracket for a spare wheel to hold it upright.
Any thoughts on this also
barry
I would fit s/s anchor track as fitted in the back of removal vans .
Link Removed
Link Removed
Commercial motor factors usually stock ..
Google for a local supplier
whatever solution you use i'd be very careful as to where you fix any securing rings/hooks.
there may be some timber battens within the rear wall for fixing cycle racks etc, but knowing where they are is a different matter.
the wall itself wont be strong enought to take much weight on its own.
John is correct, however, anchor track, (sometimes called cargo track) has lots of fixing holes so it spreads the load along the wall rather than at one point.
I have fitted these in trailers with thin walls.. even onto thin plywood they are fine if you have plenty of fixings ..
found this supplier .. s/s and zink
http://www.nationwide-trailer-parts.co.uk/load-restraint-lashings-straps.html
Thanks for the pointers
Thanks chaps
certainly Im not going to drill anywhere there might be issues
But some solid ideas there........many thanks
barry
Use a stud detector to find the timber framework behind the walls, you can get them from B&Q and the like for about £10.00 and they work really well. :thumb:
The FIAMMA catalogue is the best place to look.
Lots of Garage solutions in there!:BigGrin:
