Thule electric step probems help required (1 Viewer)
Portland
923
1,424
Conwy
C class
20 years
The step on my Autotrail Savannah is very eratic when working, sometimes not working at all other times stopping at random. It goes down first time of a morning. But never fully retracts.
The step action is totally free, the motor is new. Motor replaced due to sheared gears, tried Sargents many times but have no reply
icantremember
8,262
17,206
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We had a similar problem on a Autocruise Augusta which was caused by a fault in the Sargent unit .. it was replaced under warranty and all was then well.
Apr 27, 2016
6,565
7,429
Manchester
A class Hymer
Since the 80s
Another possibility is the switch. Is it a separate switch or is it in the Sargent unit?
Nov 13, 2012
439
437
Somerset
coachbuilt
since 2000
Had same problem on my savannah it was a small drive shaft for operating step took dealer 15 minutes to replace apparently a common fault.
Jaws
23,765
74,956
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
It will be the Sargent EB50 box .. Pretty common .
I spent weeks trying to sort mine out.. I even removed every component from the board, replaced all the TTL chips, the diodes, and transistors.
In the end I gave up and sent it to Sargent.
Got one back ( a replacement ) almost by return with a hand written note saying they could not find the fault either !
Some time later I received an email..
The fault was an intermittent break in one of the connecting tunnels between the board layers.. Made me feel a bit better about not finding the problem myself :)
