NickVick
The tambour door on our Tramp 554 has come off its fixings - has anyone had any experience of how to fix this back into position.
I repaired the one on my Adria using 2mm bolts & nuts.No picture at present but have seen the same problem with 'Porridge Oats' June 3 23, and their picture is exactly the same as our door.
Different on mine then , all the weight was supported from the top.I unscrewed the top guide rail and moved the guide and door inward to allow more room for the door and top guide pins to slot in.
Once everything was in place, I carefully moved the the door including the guide rail back into position then screwed the guide rail back in place.
I am still not sure if the top guide pins should hold the weight of the door, they don't on mine. All the door weight is supported from the bottom guide rail.
Thank you for all the replies - will attempt to unscrew the guide rail and replace the top guide pins, they do not seem to hold the weight of the door which means that during use the door pulls away from the guide pins. We are going to try the 'nuts and bolts' to the guide pins through the door. This has been the only disappointment with our Hymer van (we purchased it only two months ago), everything else is working fine. Will keep you updated as to if this is successful.The tambour door on our Tramp 554 has come off its fixings - has anyone had any experience of how to fix this back into position.
