swift royale
stuboy7
folkestone kent
coachbuilt
2nd year
hi 2 u all, has anyone got a swift royale 610? 1998.:thumb:
hi on my main trip switch is a button to test if i push it the trip should trip off mine does not any 1 any ideas? also got no power to plugs working.:Smile:
yup we've got-one.
Have you deffo got power to the trip-switch?
Silly question are you switching-it the right-way?
Fuse in the hook-up lead blown?
If there's no power at the plugs then it's got to be around the breakers have you checked the others?
regards...nige
hi nige, have gone thro fuses all ok have got lights in rear of van but no power to 3pin plugs and cant get carver heater to light got gas into van, in wardrobe is main switch says if u press test trip should trip and go down but dont, stuart:thumb:
The lights work off the leisure battery, it sounds to me like you've not got any 240v
at the moment. check the fuse on you're hook-up adapter and that all is fully pushed in all round.
regards...nige
ps check the other two trips :Doh:
Hi stuart
I've just tried mine and the switch doesn't trip, i'm not hooked-up to the mains!!
Somethings wrong between your trip switch and the plug socket your hook-up's plugged into, now if it was me i'd (a) try something else in the plug socket to make certain that it's working (b) change the fuse in the adapter (c) plug my adapter into the van and try an ordinary extension lead. After that i'm starting to struggle
regards...nige
thanks peter, passed your place other morning about 8am had a look at your stock some v nice m/h. also noticed your large shop which i told the wife she said a visit was needed to stock out m/h so will see you in near future.:thumb::thumb:
