Thanks, mine is leaking where the head joins the motor, I've tried tightening to no avail, I may whip it out and take a better look.Hi, where is your pump leaking from, I had a slight weeping happening that I only found when I was investigating why the pump kept purring after use and in the end non stop, I found the screws holding the head on the motor were a little slack allowing the pressure to drop and the weeping, I also found that by taking it apart (2nd time) and cleaning mating faces that the diaphragms had bits in them stopping a good seal and thus not getting the suction needed to prime and pump so I had it out again and gave it a good clean, now working spot on, build pressure up and no leaks.
Nigel
I did that a few years ago still going strong!Take the pump part off and refit with a smear of silicon grease on the mating surfaces. When refitting tighten the screws a bit at a time in rotation and don't forget to put removable thread lock on the threads.
Thanks, that's just what I needed to know, as they are available but the 112 isn't.
