Skyway
- Jun 8, 2020
- 676
- 668
- Autotrail
I done that but only give me an option off smartOn the EC480 go to the home screen the one with the Autotrail logo .then press both the up and down arrows at the same time.hold till you hear a bleep.this will take you to the settings menu. Scroll through using the up/ down arrows until you come to the solar settings ..then turn off the solar. And see if that cures the problem. If so you know it's your controller
I do have a pay ec500 correctIf ,as I suspect , you have a PSU EC500 unit to go with the Ec480 display it would have an inbuilt solar controller which has not been used and a separate split battery charge controller used with your solar panel (s) set up, not a problem, but I wonder if this would effect the ability to turn them off at the control panel ?
Right I got my panel today going to wire it in like for like to the old oneYour control panel probably showed a high battery voltage reading before the system shut down which would have confirmed that excess voltage was being the cause of the problem , yes the black box is the controller and it is a duel charging version which means it splits the solar charging between both the leisure and starter batteries. (some types of controllers only send the charge to either the leisure battery or the starter battery but not both). It may have been used instead of the EC500 built in controller as they are limited to 120 watt solar panels max. (or possibly as a replacement for a faulty built in one)
When the solar controller is replaced it is important that the batteries are wired to it before the solar panel wiring connections are made to it. (this is so that the solar controller knows it is operating with a 12 volt system)
