Hankandmarvin
Hi all,
What's people's opinions in rotating tyres? Do you need to do it or not? Thanks
You swop front to back.Hard to rotate when they are directional although mine are not CP rated tyres just C
That only applies if your spare is different to your rolling wheels, always best to have the same for a spare.Adding the spare into the mix is too complicated as it's on a steel and the others on alloys. Although the first change of the fronts I use the spare and one new tyre and the best of the removed ones goes on the spare.
That's interesting. For 50 years, ever since my first Mini, I've always ensured that the best tyres are on the front for best steering (and grip with front wheel drive).Swapping front to back is a complete No, No, as the best tyres should always be on the rear for safety.
Yes i always thought that too.. regardless of front or rear wheel drive surely for safety sake it's better to have good grip for steering (and braking) than at rear.That's interesting. For 50 years, ever since my first Mini, I've always ensured that the best tyres are on the front for best steering (and grip with front wheel drive).
They would be well past the recommendation to change before 6 yearsYou swop front to back.
On most of my vehicles if I swop front to back then you can get 50k miles out of them all. no swopping then front used to get changed twice & the back would need changing due to age/cracking but plenty of tread left.
Correct....understeers straight into that brick wall you were safely going to missIt is understeer versus oversteer . If the best/new tyres are on the back & the front loses grip it understeers. If the best are on the front & the back lets go You've crashed unless a rally driver.
A front wheel blow-out is easier to control than a rear with a tall and heavy vehicle. See also comments re under- and over-steer.Yes i always thought that too.. regardless of front or rear wheel drive surely for safety sake it's better to have good grip for steering (and braking) than at rear.
6 years, I'm pleased if a set of tyres last 3 years on the Motorhome, car ones last for ever as that doesn't many miles compared to the Motorhome.They would be well past the recommendation to change before 6 years
I have to disagree with you there Gus.It is understeer versus oversteer . If the best/new tyres are on the back & the front loses grip it understeers. If the best are on the front & the back lets go You've crashed unless a rally driver.
3mm is absolute min on a heavy vehicle a legal requirement in a few countries in the winter, Germany for one.Decide that the tyre tread depth range between new & 3mm is safe.
Should you fit new tyres to the front or rear?
You’ve bought a new pair of tyres, but here’s a question, should you fit your new tyres to the front or rear?kumhotyre.co.uk
ShieldSquare Captcha
www.oponeo.co.uk
Good point. I did revert to mentioning a typical value mentioned for cars rather than thinking of a motorhome.3mm is absolute min on a heavy vehicle a legal requirement in a few countries in the winter, Germany for one.
Agreed front wheel drive does put more load on the wheels but in all honesty I just change all 4 when either the front or rear start getting low (3-4 mm) then each corner starts with a brand new tyre.That's interesting. For 50 years, ever since my first Mini, I've always ensured that the best tyres are on the front for best steering (and grip with front wheel drive).
