Remis Blinds
SnJ
NuL, Staffordshire
2009 Autotrail Dakota
Why do they do this... Its beginning to p*** me off now.
Any suggestions on how to stop it & fix the problem?
Rusty
Usually caused by having the window open with the blind down, wind blows it out of the guides.
Similar problem can be had on The Seitz Screens, I would like to know how to adjust them so they stay up at night, the magnet seems to be weaker on the ones used most, like the bedroom.
SnJ Have you tried removing the side vertical frame covers to see if you can relocate the screen back into its vertical guides? I haven't checked yet but maybe there is a fix shown on You Tube. I think you will have to take it off the window to sort it out somehow.
Good luck, I see how frustrating it must be for you.
LES
Not happened since we have the MH.
However what I'm actually after is a solution the issue of it not folding away properly
LES
LES,
Thanks for that bud.
I haven't removed the sides yet, was going to be the next plan. Just wondered if there was an easy solution before I started dismantling stuff
This happened on my last 'van. In that case it was sun/heat damage distorting the fabric as I used to keep the blinds closed when parked. I never did find a solution!
It may or not work but spray a little *Fabreeze* type fabric conditioner on the blind when extended, we do this and have no problems at all with ours as it softens the structure of the blind, not claiming 100% but works for us , keep it subtle !( PS it smells nice as well)
Hi.
When it starts to happen,i pull them tight/closed.. then when putting them back in their holders,gently tap the folds with the back of my hand. Same problem sometimes with the Fly screen on the door,same procedure. Works for me. In the pic where it is trapped, One,you should have stopped pulling,close/open ?then where possible,i would open the window and get your " Trailer mate ? " :ROFLMAO: to get the other side and gently ease it back with you as you operate it . They have a memory,so like to fit in the right way.
Tea Bag
