Just want a decent quality one really. Manual or digital. Needs to be fairly accurate up to 5 bar
Thank you in advance!
What about a cycle track pump? that’s what I use.
We have the Topeak which goes to 160psi - info. & more discussion here https://www.motorhomefun.co.uk/foru...o-your-required-pressure.206004/#post-3528946They also keep you fit!
Bee recommended to get one by fellow funsters Wombles, dont know which model they have but here is an example of one on Amazon, there is even a video to look at!
LES
Amazon product ASIN B009KLWRG0
Are these seriously good enough for tyres at around 70 psi that need keeping at that.We have the Topeak which goes to 160psi - info. & more discussion here https://www.motorhomefun.co.uk/foru...o-your-required-pressure.206004/#post-3528946
Looks like this is the latest version https://www.wiggle.co.uk/topeak-joe-blow-sport-iii-track-pump
Yes - we have found it good for keeping our tyres topped up to 72 psi (on rear) - about 10 strokes for each psi but use body weight so it's not difficult.Are these seriously good enough for tyres at around 70 psi that need keeping at that.
Are they strong enough and how difficult are they to depress?
Do you have a link please?Yes - we have found it good for keeping our tyres topped up to 72 psi (on rear) - about 10 strokes for each psi but use body weight so it's not difficult.
If doing many psi then might feel it a bit on the arms but less strenuous than a footpump & cheaper than 12V inflators that can fail if not a heavy duty model. We used a Ring one that would blow fuses each time then a Ryobi One+ that kept struggling then stopping even though fully charged so happy with our wildcard track pump option suggested by a helpful FunsterIt does need to be one that have capability of a high psi so look out for that.
Yes, I did think that on the volume required of a MH tyre versus a very thin road bike tyre.They can easily reach 70psi, most road bike tyres run at minimum 80psi and more likely 100psi plus.
There is, however a vast difference in volume requirements. It takes a hell of a lot of pumping to put significant amounts of air into a mh tyre with a track pump.
We bought ours from Wiggle but £31.99 there - found 160psi model cheaper here at £27.99 delivered http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=174391975629 - looks like the seller has a proper bike shop. If you use Quidco don't forget to go through that to eBay for a tiny bit of cashback tooDo you have a link please?
the Ring RAC900 looks good. My van is 8m long so it’s likely this will stretch from the cab battery to the rear tyres?
They say there’s no such thing as a stupid question, so: do i need to take any precautions when i clip it to the battery under the bonnet? Like, take out the ignition key and switch on after its connected? I'm sure it will include a user manual but i may as well ask
I have one of those. Very good. Long enough reach for me, using battery under bonnet. I don’t normally have the engine running as only topping up the pressure from time to time,but if going from flat then I would.the Ring RAC900 looks good. My van is 8m long so it’s likely this will stretch from the cab battery to the rear tyres?
Got the very same works a treat.Similar to the ring it's the
KATSU Tools 451717 12V 30A Double Piston Large Volume Air Compressor Car Tyre Inflator
From Amazon that's the price now
Price: £27.99 & FREE Delivery
Needs this at £2.70 for easy use
