Recommend me a monitor!
Stalk
Northampton
Not Yet Purchased
Not Yet
Hi All!
We have an Autotrail with a drop down monitor, and it’s crap. So what’s a good replacement? It just needs to be a fold down monitor, the DVD player is in the dashboard, and the satellite box is in the cupboard but I am willing to consider alternatives.
Cheers All!
What size......? :unsure:
Sorry, about 18 inch diagonal. Also realised that I have posted in the wrong section, so I have reposted in the correct place
Ok....is your current flip-down monitor fixed to the flip-down bracket by screws, and are the screw holes at VESA spacings (100mm, 200mmm etc.) - or do you want to replace the whole bracket/monitor set up......?
You haven't mentioned the model of your AT so this may, or may not, be relevant to you.
We have a 2013 Savannah and it has a drop down monitor above \ between the cab seats however as these rotate and are much more comfy to use rather than the other chairs \ benches we fitted an additional TV that can be viewed from the rotated cab seats.
Our drop down monitor has fixed fly lead cabling to the back of the dash mounted media centre and to replace we would have needed to remove the cab headlining and "A" pillar fittings for the Remis blinds to access these. We did replace the OEM fitted 13ELE media unit though as it was cr*p.
