Mikey RV
Anybody had their Fiat Ducato engine remapped. Thinking of getting mine done so I will have more torque for towing, making life easier on the hills etc.
Ive had my car re mapped and its brilliant however don't think i would have the MH done as too much potential strain on the clutch and drive train.
was always against remapping.
but had to have some work done on the ECU. so they remapped
from 130 bhp and 320Nm torque
after remapping
180 bhp and 420 Nm torque
not sure i notice the 50 bhp but the extra 100 Nm torque is very noticeable..... smother, stronger on hills, fuel economy a smidgin better by around 1.5 MPG.
one of the best things i have done.
I had similar thoughts but having driven it now for over a year with the additional torque and BHP i have changed my mind; I think that unless you grab the gears slam the foot down and "drive it like you stole it"! there is little extra strain IMHO.
but when you need the extra torque in towing or on steep hills what a difference, you are not up and down the gears as much so arguably less strain on clutch and gearbox.
Hi phil...what was the cost if you dont mind me asking? We have been looking into this too..
Kev
I still worry about the clutch. They are not very good and can fail on a standard Ducato at 35,000 miles
@Phill D
This has been raised many times before, and I have read with interest, as I am doing now. May I ask how old and what mileage your van has covered? The reason I ask this is that I feel that those who are still under The Fiat Warranty, or have not fully run in their engines say 15K plus would be best advised not to do this, just in case of a warranty claim.
I take it that your EGR needed de-sooting, which is a common problem on many diesel engines.
Some did report clutch slip in top gear up hills with clutch fully engaged, but they must have clocked up a few miles before that happened.
Good luck hope all goes well, I am sure some will question the 50 extra BHP increase,but we shall see.
Les
My would slip when I tried to use more torque up hill instead of changing down
Silly question but..If it shows signs of slipping when in a high gear...Normally that would indicate a worn clutch any way. Having worked all of my life in the heavy traction unit and Fork lift truck dept Field service with Caterpillar and John Deere and McCormick tractors ..the simplest test on any small vehicle to determine clutch faults was to put it into a high gear and try to pull away. If it stalled it was ok. If it slipped and then took up drive...it was ermmmm...buggered or due to be !My would slip when I tried to use more torque up hill instead of changing down
sorry,, is that a statement of fact or you feel would be your luck?
Yep it was on its way out at 35k and I had to nurse it back from South Germany. These are not the most robust clutch and that's why I pointed it out.
Pulling 3.5+ tonnes permanently is not going to help towards a long life clutch - even for a commercial van.
Asking it to cope with extra HP/torque can only make it worse. IMHO
I'm not not sure what you mean.
Did my older 2.8JTD 3 years ago, a big difference in torque - a distinct improvement
Anyone had a 2.2 2015-on Peugeot boxer done? Wouldn’t mind 150bhp on mine![]()
Blummin eck, just looked on quantum site 200bhp 419nm torque!!according to the Avon tuning web site a 2.2 2015 110bhp boxer can be remapped upto 180bhp and 420 Nm torque
