Rapido 9-series heated mirror problem
mid-Norfolk
Low profile C class
since 2006
My external mirrors no longer defrost (nor dry out in the rain) and the little green light on the switch no longer illuminates, although they have functioned perfectly for 14y.
The handbook says "1 15Amp fuse, accessible on relay located behind the satellite on driver's side" whereas other circuits are described as "behind the control panel" [which I'm assuming relates to the specific item namely Truma valve and fridge] or "under driver's seat".
These positions seem to be independent of the base manufacturer.
Does anyone KNOW where this 15A fuse may be please? I have found one 15A fuse "behind" the Scheiber control panel, which is by my hab door. The mirror heater is, in fact, the only fuse mentioned as being "behind the satellite" although there are 3 fuses (20A, 15A, 30A) behind the Scheiber.
I have checked three 15A fuses under the drivers seat BUT behind the main rows of fuses and relays.
Every 15A fuse which I can find is OK but someone may have replaced it with the wrong size fuse before I bought the MH.
If it's not the fuse, any suggestions as to my next move please?
TIA - Gordon
Try the rapido Facebook page someone on there will have the same van
