Puraflex/Soudaflex?
Warwickshire, UK
Westfalia Amudsen
Found a leak in a the bathroom coming through the Remis roof light this weekend so taking inspiration from Northernraider ’its only an hours job’ 😂 I’ve got it off and all cleaned up.
Took me about three hours to clean it all up including removing a rounded screw head on the internal clamp as it came from the factory 🙄
Planning on using the Puraflex replacement Soudaflex instead of the non setting stuff as recommended here.
Question is, do I stick it on then run a bead around it and smooth out? Or should I use the non setting stuff?
Paul
