JaneyBMotorhomer In Hants
Just thought I would post this in case anyone else has had the same problem. We have a Phantom cat 6 tracker on our AutoTrail. It comes with an app for your phone. This app updates regularly confirming the location of your motorhome and also battery and mileage details.
I discovered yesterday that it had not updated since May 17th. After a lot of faffing about with Phantom and the dealer it appears that the problem is as follows: The Orange network no longer supports trackers. My vehicle was trying to log on there and failing. To overcome this problem you need to re-boot the tracker. This you do by opening the fuse box (by your right hand knee when sitting in the drivers seat, it is a Ducato by the way). Look in there and find the plug at the bottom left, under the green flap - the one with the red circle round it in the picture below. The Plug has one red wire, one black wire and two blue wires coming out of it. Pull this plug out and leave for 24 hours. Then plug back in and it should have re-booted and should connect as normal.
However, I got as far as unscrewing the fuse box and then noticed that my tracker app had updated a couple of minutes before after 5 days of inertia! Phantom checked it out and it is now connecting to Vodafone.
The reason for posting this is Phantom told me that I am the 4th person recently that has had this problem so someone out there might be searching this site for info!
