I appreciate this is not MH related but I know there is a lot of talented people on here, so hopefully someone will understand the above heading more than I do.
Having fitted a Bafang BBS02 kit to my bike the left crank arm became loose. When I removed the bolt there were metal filings on it which I suspect means the thread may have been damaged. The thread is part of the motor. It has been suggested that I should have used a torque wrench and tightened it to 40Nm. If I can confirm that is correct, that will be my next step, with some blue Loctite.
Planning ahead with my pessimistic head-on and with few skills in this area I am planning ahead should the above not work......
Although I would rather not, removing the motor is possible. It has been suggested that re-tapping and/or helicoiling may be an option.
I know that both of these options are not in my skill-set, just wondering what sort of small businesses would find either of these options a simple task. I am assuming that if you know how to do these and have the tools, what you are working on doesn't really matter, but I could be wrong.
Any suggestions of the types of businesses I should contact or any other suggestions/ideas would be most welcome.
Steve
Steve
