Moisture meter
MHpe
London
I'm a newbie
Would not go for a four probe model as with a two probe you can better get to out of the way (and therefore not noticable) areas like under window rubbers (don't let probes touch the rubber as it may have carbon in it and therefore conduct) and around hatch frames.
Pin meters are ok for checking moisture in timber.. or logs for burning.. cheap and cheerful
Non invasive is better for structural testing..
I have this one..
CEM Non Contact Moisture Meter - DT-128
Link Removed
forgot to welcome you..
:welc:
I have one of those too Jim. Great if you know whats behind the panel (it is a bulk measurement meter) and interpret the reading accordingly. Finds cables and metal reinforcing as well.
Hi and welcome -I too have same meter as Jim and on testing it on a friends Swift Kon Leaky MH it was extremely good and accurate at finding damp areas above 15%(of which there were plenty unfortunately!)
Ian
Got mine from Maplins.. The only downside of it is that it tends to eat batteries if used a lot ( but most folk would not be in that position )
http://www.maplin.co.uk/p/moisture-meter-n20fr
Me, I tend to pay a bit extra for anything tool related.. and I have had so much duff/cheap and nasty kit from Amazon I only buy stuff from there that canna possibly go wrong nowadays !!
Ian
Did you really need a moisture meter to tell you that ? :D :imoutahere:
there were some reduced in my local Aldi today -the none invasive type -£8.99
