Hi, what are people using on top of memory foam mattresses.
thanks
thanks
We are using a sheet, but finding them to hot.A sheet![]()
Ours from Jonic is not only lighter than the original mattress by a long way but with a mattress protector is reasonably cool.If you're at the stage of thinking of buying memory foam mattress just note they're hotter than a normal one and very heavy. If you have one and finding it hot tencel sheets can help.
I avoid memory foam at all costs for the reasons above. My bed has a Zonesleep topper on it which is breathable and has transformed my sleep in the van.If you're at the stage of thinking of buying memory foam mattress just note they're hotter than a normal one and very heavy. If you have one and finding it hot tencel sheets can help.
That 2 inch mattress weighs nearly 8 stone!! Surly not.Been using this for over a year now, including nearly 3 months constant use at the end of last year during a house move, never had any problems and not too hot either
Coolmax Affordable Memory Foam Mattress Topper | 5cm 50kg
The Coolmax 5cm Memory Foam Mattress Topper is your ticket to blissful sleep. Ideal for hot sleepers on a budget - upgrade your bed with this cooling topper!www.memoryfoamwarehouse.co.uk
